Old 12-02-2005, 01:05 PM   #15
mtnman's Avatar
Collettsville , North Carolina
I think I know how to get my coach home! I just need a little help here. I have a new equipment trailer with new tires. Its a dual axel with
ST225/75D 15 8ply tires with 65psi. They are 5 lug Wheels.
How many lugs on the Argosy?
Anyone know if they are the same and will fit on the argosy minuet?
Does anyone know what the measurments are?
mtnman
mtnman is offline   Reply With Quote
Old 12-02-2005, 03:43 PM   #16
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
off by one lug..
the rim is a 15x6.5 (15x7 will do) and 6 lugs on a 5.5" pattern.
Here's the pattern for the pigtail and car end
http://www.marksrv.com/wiring.htm
When are you picking it up?
Marc
Old 12-02-2005, 04:55 PM   #17
mtnman's Avatar
I was wanting to go get it tomorrow, Sat. I am still trying to decide what to do about the tires since my equipment trailer wheels are 5 lug that option will not work. I found some new trailer tires locally for $54 each, carry out price. I may try and pick them up in the morning and head toward the Coach. The seller found some tires at a tire dealer for $288 put on but I beleive they are too big, he didnt know for sure what size they were. He thinks they will fit but I dont want to get all the way over there and then they may be the wrong size.
mtnman
Old 12-02-2005, 05:06 PM   #18
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Go for it!
With those tires, and especially since it is a double axle, I'd go for it, just take it easy. Don't go over 45, and do not fill to max pressure, as the tires heat up they will expand. I'd get er home....
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 12-02-2005, 05:11 PM   #19
mtnman's Avatar
robandzoe,
I thought a bunch of time about "going for it". Did you see the pic of the old tire? Its 60 miles, would you still go for it?
mtnman
Old 12-02-2005, 05:18 PM   #20
robandzoe's Avatar
Plymouth , New York
Yeah, I would
I would. Do you have anyone to follow you, with a little 2 way radio or cell phone? It is a double axle, right? At 45 mph, that would be a 1 hour and 20 minutes. 30 mph, two hours..but you'll have it home to work on it, as obviously, you are not working on it now. Check out my blog, http://sweetsovereign.blogspot.com , like I said, we towed that 46 Vagabond on its original tires 3 miles on just one of the two axles...where are you towing it from and too? If you were near me in NY, I have two good Good year marathons you could borrow. I also picked up a 76 Argosy on very old tires, and once on the Interstate, pulled 55 mph for 200 miles, no problems....on at least tires that had been sitting for 10 plus years...5 months later, pulled it another 100 miles.....I also bought a Trade Wind..it has 4 car tires on them...pulled from Va to NY with no problems. Just stop and check often, feeling the hubs and tires for heat. Good luck...just take it easy. I know of many others that have done the same....
Rob
Plymouth, NY 13832
Courtesy parking
Old 12-02-2005, 05:20 PM   #21
mtnman's Avatar
Marc
Ok 3ms75Argosy, I got on that site and printed out the diagram to take with me, thanks! That is a good site to have, I saved it to my favorites.
mtnman
Old 12-02-2005, 05:28 PM   #22
mtnman's Avatar
I would. Do you have anyone to follow you, with a little 2 way radio or cell phone? It is a double axle, right? At 45 mph, that would be a 1 hour and 20 minutes. 30 mph, two hours..but you'll have it home to work on it, as obviously, you are not working on it now. Check out my blog, http://sweetsovereign.blogspot.com , like I said, we towed that 46 Vagabond on its original tires 3 miles on just one of the two axles...where are you towing it from and too? If you were near me in NY, I have two good Good year marathons you could borrow. Good luck...just take it easy.
Rob
Rob,
Thats nice of you to offer the tires but the coach is in east Tn and I am in western NC. The last 10 miles is all dirt road to my house but I am still thinking about going for it. Yes, I have help. My nephew wants to go with me and we can take radios and a second car. He is as anxious as you guys are for me to get this baby home and start work on it! He has call me twice today wanting to go with us.
mtnman
Old 12-02-2005, 05:28 PM   #23
mtnman's Avatar
I got to go eat, I will back in a little while.mtnman
Old 12-02-2005, 05:41 PM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by mtnman
robandzoe,
mtnman
I bought a 77 Argosy with tires that were worse than those. Towed it 15 miles home, then 8 miles to storage, 8 miles back, etc. It added up to more than 60 miles on them. Two of the tires would not hold air for more than an hour or so at a time, I was very happy when I finally got new tires on it. If you aired up your tires when you went and looked at the trailer, and they are still up, use them to get it home. Just drive slow, and stop and make frequent checks of the tires, and make sure nothing has come loose on the coach.
Also, it would be much easier for you to tow the trailer over to a tire shop and have tires mounted on the trailer, than taking off the tires and wheels two at a time, and getting tires mounted on the wheels, and then going and getting the other old tires...You get the idea.
Old 12-02-2005, 05:50 PM   #25
robandzoe's Avatar
Plymouth , New York
A rareity
mtnmAN,
You have luck on your side...already...probably ot even knowing it....Being that it is near western NC and the famous RichardT from Bat Cave did not get this Argosy....What size Argosy is this one?
Rob
Plymouth, NY 13832
Courtesy parking
Old 12-02-2005, 06:05 PM   #26
mtnman's Avatar
Its a 1979 argosy minuet 7.3. I bought it from a friend. Bat Cave is aways from here over toward Asheville, NC.
mtnman
Old 12-02-2005, 06:08 PM   #27
mtnman's Avatar
here are some pics on this thread:
http://www.airforums.com/forum...uet-19432.html
Old 12-02-2005, 06:26 PM   #28
mtnman's Avatar
Rob,
I checked out your site, I dont think I would have touched that one. Did you check the wheel bearings and at what point did you check them? Were the wheel bearing still good? I am concerned about the bearings on this 79 but I believe they are ok. Reading your post and overlander63 post has given me new confidence, I think I am going to go for it.
mtnman
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 07:51 PM
WTB Used tires for Argosy MH manley General Motorhome Topics 2 12-11-2002 11:23 AM
