Old 06-20-2012, 10:22 AM   #1
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
Tanks
Does anyone know if the commode on a '79 Minuet 7.3 sits above the floor or below the floor? I don't want to tear out the bathroom if it's under. The reason I ask is the commode sits on a bump=up about 8" tall.
Paul
tarnished is offline   Reply With Quote
Old 06-20-2012, 10:28 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If the raised area is large enough it sounds like above the floor.
You should be able to tell by looking down the toilet with a flashlight or using a piece of coathanger bent at an angle to probe around
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-21-2012, 05:54 AM   #3
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
That porch the toilet sits on is a cover for the top of the black tank with the drain down through the floor slanted street side. The black tank sits on the floor if it is anything like a 6m Minuet of the same year.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 06-21-2012, 07:31 AM   #4
Topping , Virginia
Thank you for the replies. It's todays project.
First the coat hange then try to trace the piping.
Paul
Old 06-21-2012, 08:15 AM   #5
1974 Argosy 20
Kooskia , Idaho
I am pretty sure it sits on the tank, which is above the floor. Most all Argosy's used that system and a low profile toilet on top.
Old 06-24-2012, 09:30 AM   #6
Topping , Virginia
As suggested the commode sits on top of the tank. What the heck once you start you've gotta go all the way.
Removed the toilet cleaned, disassembled and ordered new seals etc. Dumped some cleaner into the tank, mercifully empty but stinky, got the dump valve working for both tanks. The drains in the sink and shower seem slow, now currently working on them.
Lastly will be the belly pan to clean and paint the frame check for floor rot and leaks and check whatever else is there.
Paul
Old 07-02-2012, 05:00 PM   #7
rogerdodger's Avatar
Fresno/Clovis , California
Paul
What do you do for a slow sink drain?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 07-03-2012, 09:23 AM   #8
Topping , Virginia
Used a commode plunger for the shower pan, gently so as not to break anything and some pces of junk apparently moved as it is a bit faster running now. The belly pan is off in the rear. I hate the thought of removing the trap so am still using the plunger. Removing the trap in the sink was easy enough, it was
full of 'no idea what black stuff' but clean now.
Paul
Old 07-06-2012, 10:16 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The vent stack to the grey water tank may be obstructed.
If the air can't get out, the grey water can't get in. Most have screens, look for a mud dauber nest or something similar.
