Old 01-16-2015, 07:00 PM   #1
ffrick
ffrick's Avatar
1977 Argosy Minuet 6.0 Metre
Centerville , Massachusetts
Smile Tambour doors
After over a year of fighting with my overhead cabinets sticking, I found a really simple solution. I thought I was going to have to take them all apart and rewind them or whatever it would take to make them slide freely. Before going to that trouble, I figured, what the heck, they are made of a plastic material. I just carefully sprayed wd40 along where they slide. Then, carefully wiped off any excess oil so it wouldn't drip on my upholstery. After a couple of tugs up and down, they work beautifully. I did the same on they cabinet door below the galley sink.
Just figured I'd pass this on to all. ffrick
ffrick is offline   Reply With Quote
Old 01-16-2015, 09:02 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Don't get me wrong WD40 is great stuff but the smell can be a bit much especially if you're doing a lot of doors and its summer. If you don't want the smell but want the same lubricancy, try PAM or any aerosol cooking spray. If you like the smell of butter, there are butter flavoured ones too. I use PAM on my snowblower chute and any moving parts for the cold as PAM won't freeze.
Cheers
Tony
Old 01-17-2015, 07:22 AM   #3
aquinob's Avatar
Portsmouth , Virginia
I think I would try a silicone spray lube before using some sort of organic oil spray.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 01-17-2015, 05:07 PM   #4
ffrick
ffrick's Avatar
Yes, I agree that you could use pretty much any lubricant that suits your fancy. I was just so happy to discover that it wasn't a mechanical issue with the 38 year old cabinets. Thanks for the input. ffrick
Old 01-17-2015, 05:36 PM   #5
Ottawa , ON
I totally agree with you on this.
In fact, I find that silicon spray is a great friend for loosening things up on our Airstreams. The main door (on the rubber gasket) the windows' gaskets too, and even the striker pocket on the door. It lubricates, but leaves no greasy residue, nor does it get sticky with age.
Old 01-17-2015, 05:54 PM   #6
terryV's Avatar
2002 31' Classic
Monroe , Iowa
What's that spray lubricant that smells like bananas? It works pretty good, also.
terryV is offline   Reply With Quote
Old 01-18-2015, 05:35 AM   #7
ottawa (greely) , Ontario
Cheers
Tony
Pam is great on snow blowers if used on the chute snow doen't stick and blows the snow further ( that wet sticky snow) I also use it in my tractor bucket so the snow doesn't stick to the bucket when dumping it .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-18-2015, 05:38 AM   #8
Be careful silicone spray does destroy some plastics! So I wouldn't use it on the tambour doors in my airstream
Don
Old 01-18-2015, 08:46 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I too use silicone spray on my 2008 SS tambour doors
Ahab is offline   Reply With Quote
Old 01-18-2015, 10:13 AM   #10
1976 31' Sovereign
Oswego , Illinois
The tamb. under sink only open part way, no amount of effort will not open further, can not reach behind to check if some thing in can it rolls into as it's enclosed except where tamb. goes into it. All other tamb. used wd 40 they roll fine, used wd 40 under sink no go, as stated before. Any ideas?
Old 01-19-2015, 07:15 PM   #11
Ottawa , ON
It's often dirt in the track that allows them to bind up. Try cleaning the track with just warm water with a dab or tow of dish detergent in it.
Old 01-19-2015, 07:29 PM   #12
1981 31' Excella II
New Market , Alabama
You want food grade Silicone Spray. The stuff at the auto parts store will have the same solvents that WD40 has.
Perry
Old 01-20-2015, 08:15 AM   #13
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Have you tried lifting up on the front edge of the kitchen tambour as you try to open it? Sometimes they bind in the bottom track and lifting relieves the bind enough to get it to move. The tambours I have seen seemed to have a fair amount of slack between the top and bottom tracks so the tambour can be moved up and down. Opening and closing the tambour tends to load trash into the lower track and compact it. If you get the door to open, disassemble it and clean the track.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 01-21-2015, 08:03 AM   #14
1981 31' Excella II
If you use cooking type oils they will eventually harden and turn to gum and get sticky which is really going to make your life difficult. Silicone leaves every little residue compared to other lubricants.
Perry
Tambour Doors Repair 71excella500 Cabinets, Counter Tops & Furnishings 27 11-05-2016 08:33 AM
cost of replacing all tambour doors pearl Cabinets, Counter Tops & Furnishings 9 08-17-2004 05:11 PM
Reinforcing Tambour Doors Navigator Cabinets, Counter Tops & Furnishings 1 03-04-2004 11:28 PM
repaired the tambour doors remcolent Cabinets, Counter Tops & Furnishings 12 01-13-2004 08:02 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
