Old 05-14-2008, 11:41 AM   #1
Hawkeye5's Avatar
1973 Argosy 22
Hendersonville , Tennessee
System drain valve?
On my '73 Argosy 22' is the city water connection also the plumbing system drain valve or is there another somewhere?
Hawkeye5 is offline   Reply With Quote
Old 05-14-2008, 11:57 AM   #2
cameront120's Avatar
1972 25' Tradewind
If it's anything like my 72 Tradewind, there are a couple of drains that have separate valves at various locations inside the trailer. Hopefully, someone with the same model as you will chime in and tell you where they should be located. In mine, the valves are located under the galley sink and another in the rear bathroom storage compartment.
North Vancouver, BC
Old 05-14-2008, 12:24 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Hawkeye5. Your water tank is above the floor under the gaucho at the front? I'm guessing here from my recall with my '74 Argosy. If you blew 40 psi compressed air into your city water connection, it would come out any opened taps and it would push water forward and into the fresh water tank. There should be a valve low on the fresh water tank (left of center near the pump) that drains by gravity out a hose through the floor and belly pan. Pressurizing the plumbing probably won't increase effectiveness at draining the fresh water tank.
I'll willingly stand corrected by someone with fresher recall on this.
5 meter Langford Nahanni
Old 05-14-2008, 01:57 PM   #4
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
The best I can do is confirm the drain location of the fresh water tank. My PO replumbed the whole thing, so I can't tell you what a stock one has for a system drain.
biggoofball is offline   Reply With Quote
Old 05-14-2008, 06:21 PM   #5
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
There should be a check valve that keeps the water from draining out the city water supply when you are using the onboard water pump. Similarly, there should be a check valve in the piping to keep the city water from entering the water tank. There is a drain on the water tank that drains the tank. There are usually drains near the water heater and near the city water inlet. There is also a drain on the water heater itself so you can drain the water heater by opening the little brass valve and the pop-off valve. Look under the unit for hoses hanging down below the belly pan for locations of the various drain valves.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 05-16-2008, 03:43 PM   #6
Hawkeye5's Avatar
1973 Argosy 22
Thanks for the tips. When I get her on the driveway I'll crawl around on the creeper and see what I find.
Old 05-16-2008, 06:22 PM   #7
1972 25' Tradewind
Madison , Wisconsin
In my old 72 TW the pump was used to empty the tank in the original plumbing set up. There were two sets of drain valves one by the tank the other in the rear of the trailer. Th owners manual provided directions for what to open and what to close. I am re-plumbing now and the new set up will be much more efficient.
There should be a check valve that will (hopefully) prevent city water from flowing into the tank. See if you can get someone to copy the water set up from an owners manual, that may have the clearest answer.
Smokin Camel is offline   Reply With Quote
'77 Excella - Looking for Drain Valve DesertRat 1977 Excella 500 15 02-14-2008 05:22 PM
Water drain valve? ldetsf LP Gas, Piping, Tanks & Regulators 2 11-29-2006 04:57 PM
Electric Drain Valve? Walt74wra8 Plumbing - Systems & Fixtures 2 11-29-2006 04:04 AM
Plastic water drain valve Waterman Plumbing - Systems & Fixtures 5 10-29-2003 10:51 AM
Drain valve too low wayner1239 Waste Systems, Tanks & Totes 3 02-18-2003 11:45 AM
