Old 05-25-2015, 08:23 AM   #1
Casa Rodante's Avatar
1979 Argosy Minuet 7.3 Metre
grand rapids , Michigan
support for upper storage lockers in 79 7.3 minuet
My minuet has a set of drawers and two closets oppposite the bed. I would like to remove the closet next to the stove. This would give me almost a 10' ft countertop of which this trailer lacks. The closet wall seem to help support the four lockers above. MY question is whether anyone has run into this and was it necessary to create support for the lockers above once the closet is removed?
Casa Rodante is offline   Reply With Quote
Old 05-26-2015, 08:43 AM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Look inside the closet for screws going into the overhead. I would bet the closet is partial support for the overhead. If the furniture in your Minuet is aluminum frame with vinyl covered aluminum as the wall, then you might be able to use aluminum stock to form the support for the overhead replacing the side of the closet. If the furniture is wood, then building a support shouldn't be a big deal. You will likely be adding weight if you extend the counter top as most counter tops are now MDX pressed board and heavy. AS used 3/4" ply for counter top in my '78 (and '66).
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 05-30-2015, 01:30 PM   #3
Thumbs up
There is a row of rivets that runs up and down where the two front overheads meet the two rear, I would guess this is one of aluminum ribs that fashions the framework. It seems like a good idea to fashion a support and rivet it to the rib.
Old 05-30-2015, 03:34 PM   #4
Argonaut20's Avatar
1966 17' Caravel
Sounds like a plan. Without seeing the area, I can't say the rib is there, but if you have a row of rivets outside and inside in the same place, the rib is there. The closet may not lend much, if any, support. Check inside the overheads to see how the overhead is riveted to the wall. Both the Minuet and the Caravel have the overheads hanging from the wall with the closet wall as a support/stabilizer at one end. The other end is supported by channels riveted to the wall fastened to an end piece for the overhead.
2006 Toyota Tacoma
Rope lights inside roof lockers Jammer Lights - Interior & Exterior 14 05-01-2013 02:38 PM
Adding shelves to roof lockers. Forger Cabinets, Counter Tops & Furnishings 13 07-26-2011 09:07 PM
Roof Lockers - How Much Weight Can They Support? JFScheck General Interior Topics 8 04-07-2011 01:18 AM
Spring lifts missing on streetside galley roof lockers - 2010 Classic Jammer 2006 - 2010 Classic (all lengths) 7 11-11-2010 10:16 PM
