Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 09-12-2016, 03:47 PM   #1
ajrose2's Avatar
1972 Argosy 22
1976 Argosy 28
Buxton , North Carolina
Stove won't lite
The stove was working fine until we exchanged the tank. Now we can not get the stove to lite. It's is the original Magic Chef stove 1972 Argosy, and we turned the valve on under the stove top. Any help greatly appreciated.
ajrose2 is offline   Reply With Quote
Old 09-12-2016, 05:07 PM   #2
Retired.
. , At Large
Did you refill the tank, or did you get a Blue Rhino exchange?
Old 09-12-2016, 05:22 PM   #3
2007 22' International CCD
Try turning off the new tank. Wait for a while, then turn it back on very, very slowly. There is an excess flow valve in the new tanks that will stop the flow if you turn it on too quickly. Just barely opening the valve sometimes slowly pressurizes the rest of the system and avoids tripping the valve.
Old 09-12-2016, 08:00 PM   #4
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Those stoves are so simple they rarely fail if kept clean. Did you try all 4 burners? Also, turn on the valve at the propane tank, then at the stove and try letting the gas flow WHILE LIGHTING with a propane match!!!! You may have emptied the feeder line.
DryFly is offline   Reply With Quote
Old 09-13-2016, 04:30 AM   #5
ajrose2's Avatar
1972 Argosy 22
1976 Argosy 28
Yes it was a Rhino exchange, and we tried it again opening it slowly and it works!
Old 09-13-2016, 04:56 AM   #6
2016 30' Classic
Houston , Texas
I'm new to much of this. I take the lesson to be that a tank received via a Rhino exchange is a tank likely with an excess flow valve that needs to be turned on slowly. Who would have thought that - I have much to learn. Safe travels. Dennis
dhroberts is offline   Reply With Quote
Old 09-13-2016, 05:04 AM   #7
Mantua , Ohio
Good advice, Airforums Helps another, great.
Old 09-13-2016, 01:38 PM   #8
Stove won't lite
Most modern tanks with the Acme threaded connector have OPD valves. That is where the improved safety stuff came from.
Interestingly, the nut that you tighten to connect to the tank is designed to melt in a fire, disconnect, and then the excess flow valve is supposed to cut gas flow instantly. That's why all the pigtails have plastic nuts on them.
Actually not a bad improvement safety-wise, but has subtle quirks at times. Having seen a few old style tanks go nuts and leak massively, this is truly an improvement in spite of the occasional inconvenience.
Stove won't stay lit ILBambi2010 Stoves, Ovens & Microwaves 3 08-12-2020 01:28 PM
Stove top burner won't work. Jrglenn Airstream Trailer Forums 2 10-02-2014 11:28 PM
Furnace won't lite perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-10-2011 05:31 AM
Water heater won't lite imuir Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
