Old 08-01-2011, 08:48 PM   #1
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Stove/Range vent
I just purchased a 75 Argosy 26...Question for fellow Argosy owners.
Does yours have this type of stove/range vent next to the door. I haven't seen or noticed it before in photos. As you can see, mine doesn't stay flush and seems like it will be a problem going down the road.
Any suggests on a fix or replacement?
my3sonsdad is offline   Reply With Quote
Old 08-01-2011, 10:32 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have the same door on my 75 Trade Wind and it sometimes is not shut all the way, but it has never been a problem going down the road. It is controlled by a cable from a lever on the control. If the level is all the way in the closed position and it is not fully closed, the cable can be shortened.
Richard
Old 08-09-2011, 08:04 AM   #3
WOG
1975 Argosy 26
Concord , Massachusetts
Mine is in the same place. I disconnected the cable, took the hatch off, scrubbed it, bent it around with my hands and kept putting it back on (unattached) to be sure I was getting a good fit, then hooked it back up and it's a nice tight fit now. Some spary lubricant into the cable connector helps too.
WOG is offline   Reply With Quote
Old 08-09-2011, 08:55 AM   #4
Ottawa , ON
On mine, the cable was kinked where it was connected to the hatch. I straightened it out, then discovered I had to lubricate the cable because it was sticking badly.
I shot an aerosol of silicon spray into both ends, IIRC, then re-adjusted its length so that it closed fully, using the fastener (nut and bolt) which is behind the Master Control Panel on my '74 Sov.
I don't think that the Argosy units had the "Master Control Panel" (guages and stuff) but that is where the fan and door is activated on my trailer. A slider opens the hatch and at the end of its travel it turns on the fan.
The fan works, but is low power and high decibel output and so is rarely used.
Old 09-07-2011, 08:39 PM   #5
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
Spray some silicone on the rubber too to bring it back to life, mine didn't seal very well until I did that.
Greg
1976 Argosy 26'
2006 Dodge Mega Cab 1500
Glang227 is offline   Reply With Quote
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 04:44 PM
Stove Vent Motor Speed Control Road Geezer Stoves, Ovens & Microwaves 12 04-29-2011 03:12 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 03:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 05:58 PM
