Old 11-15-2002, 08:01 PM   #1
Stainless steel wool and mice
Hi Leigh,
I thought I would put this on a seperate thread. The other is getting full. I found a source for stainless steel wool at McMaster Carr, the web site is www.mcmaster.com . It was about $15 a pound. I think I will order a pound of it. It is more than I need for the trailer, but I have other uses for it too. They also sell aluminum wool. 1/3 the weight. (for those pushing the limits)
Check out all the other interesting stuff you can get there. I am still browsing it.
For this winter I used regular steel wool. If you are not towing the trailer it should be no problem. By the time spring comes I will have a rivet gun and know how to use it, and I can fix some loose skin on the belly pan. Pay attention to the front of the A frame, and the plug in cord at the back, I have heard they crawl up the extension cord and get in around the holding tanks. You should not worry so much since your trailer will be cold this winter. I am heating mine up to work on it when I can. That invites them in.
We live on a river, and the rodents are a battle. Hope you have good luck.
Do not try to pull the larger sizes of steel wool apart by hand. Always use scissors. I tried to rip some apart that way and it cut through my leather glove and gave me a nasty cut.
Have fun!
JimW
barbwire is offline   Reply With Quote
Old 11-15-2002, 08:05 PM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Thanks for the source, JimW!
I couldn't find aluminum wool, so I bought a roll of aluminum screen, cut it into strips and stuffed that in there.
Maurice
Old 11-15-2002, 08:11 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Wouldn't dissimilar metals like stainless steel wool or brass wool cause corrosion?
Shari
Old 11-15-2002, 08:56 PM   #4
Hi Shari,
Good question, I really don't know. This was a suggestion from the VACList. I have not tried it myself. This gets into some chemistry stuff that I would have to look up. The grade of stainless might make a difference, there are varying amounts of nickle in it. The idea was to take a large opening, shove it full of stainless wool, and shoot it full of that canned insulation. It might be reasonably insulated from electrolysis. Aluminum and copper is a problem with wiring. We are just plugging holes with stainless and aluminum. Maybe you can get further information? If you think about it most of your aluminum trailer is mounted to a steel frame with rivets or other fasteners. If it were a big problem I'm sure we would have heard about it.
After looking at my belly pan, I'm happy for any assurance.
JimW
Old 11-15-2002, 09:05 PM   #5
By the way, I have noticed all ground wires go to the steel frame, and not the aluminum. I'm just a newby here learning. Not the guy who knows it all.
JimW
Old 11-16-2002, 11:58 AM   #6
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Movin on
Hey JimW - Thanks for moving the thread. I was having a hard time getting to the bottom of the other with all the photos posted!! My computer is not working well for some reason, keeps locking up when pics are involved.
Thanks also for the source for the stainless wool. Not having "Mini" close by to keep track of is probibly my cause for worry. I liked being able to go have a cup of coffee with her in the morning, but living in a neighborhood that frowns on "old trailers" parked in a driveway has made her a country girl. Oh well, such is the stuff of life!! Anyway, thanks for taking the time for all of us who might need it. Now I can move on to the getting it and using it part. GTG Leigh
COArgosy78 is offline   Reply With Quote
Old 12-02-2002, 02:22 PM   #7
COArgosy78's Avatar
Images: 55
new question
Jim - I was looking into the purchase of the stainless wool and then started looking into aluminum because of the lighter weight and it says it "won't burn", which I thought "hmmm", but noticed you said something about aluminum/and/or copper and wireing. Would it be bad to get the aluminum wool and put it where there is possible contact with wires - it will short them out?? We are going to use "Mini" at Christmas while visiting relatives and I want to get this to take with us so everybody can help "stuff the trailer" along with the bird!! What a treat!! Leigh
Old 12-02-2002, 05:01 PM   #8
Hi Leigh,
It will not bother your wiring if the wiring is in good shape. Just don't put around bare hot connections, like the back of the reefer. From what I understand the wiring runs through the top centerline of the trailer, and drops down the sides. Hopefully there is no wiring under the bellypan. These are all things I have glanced at briefly while going through tons of posts. Use at your own risk.
My last comment was more of a question than anything else. I was hoping Shari had more information. Since then I have found a bit more information on the subject, but not much. 120 V grounds to the steel frame. 12 V grounds wherever from what I see on mine. From what I have read steel will turn to mush when in wet contact with aluminum, but stainless is ok. Use your own judgement, I have no reference to quote. It is all burried somewhere in the vaclist. We have always used steel wool for mouse proofing, so it made sense. If aluminum wool does not burn it might be better. One thing I thought about is if the underlying insulation gets wet, and the bottom is too tight, it might take a long time to dry out. You might wish you had mice. lol Always questions and few answers.
It took me 15 minutes and about three handfulls of steel wool to do mine. This spring I will cut some patches and rivet the cracks up. If you have a lot to do you might consider just fixing the bottom. I would be a little nervous about lots of hands poking stuff in places I did not know about. I'm just a newbie too, and look things over carefully before I do anything.
Wow, another long minuet on board!
JimW
Old 12-02-2002, 05:58 PM   #9
LOST , Hawaii
If aluminum and steel are in contact the aluminum will corrode badly (galvanic reaction), eventually becoming a flaky white mess, aluminum's version of rust. The steel also rusts, but as the aluminum is thinner it will be in worse shape.
The frame and shell are electrically the same, ground. The screws attaching the shell to the frame assure this, and I am sure there are jumpers. The 12v is attached to the shell because it is more convenient and used as a return path, less expensive and faster than running 2 wires everywhere.
120v uses 3 wires, hot, neutral, and ground. Neutral is the return path, ground a safety feature. If 120v shorted to the shell and you were to reach up to open the door, you would be ground.
John
74Argosy24MH is offline   Reply With Quote
Old 12-02-2002, 06:52 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
barbwire ~
Sorry I don't have any answers...I just raised the question.
Sounds like 74Argosy24MH has the same concern.
I just recall seeing someones' posts about having to patch around some marker lights because the backing on the light was stainless steel and it was installed right onto the aluminum without any sort of gasket between them. I also recall some posts somewhere about using Vulkem or gaskets when screwing into the aluminum with non-aluminum screws.
Anybody with a chemistry background have any input on this one?
Shari
Old 12-02-2002, 07:36 PM   #11
LOST , Hawaii
Galvanic corrosion.
You can use vulkem or a gasket behind the marker light, but that will not help where the screw touches the aluminum. Anti sieze works on machine thread screws, I don't know why it wouldn't work on sheet metal screws. I'm not a real fan of aluminum screws, a galvanic reaction will even occur between different grades of aluminum. They tend to break or strip very easily after a few years.
John
Old 12-02-2002, 08:44 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks John! All I ever wanted to know about galvanic corrosion...and then some! Seriously, great link ~
Shari
Old 12-02-2002, 08:57 PM   #13
Hi All,
The information is helpfull, but did not really differentiate between regular steel, and stainless steel. I dismantled an old boat of mine that had aluminum fittings held in place with stainless steel screws. I did not see any signs of corrosion. Are you saying stainless is as bad as regular steel? It is certainly much stronger than aluminum.
And now I'm paranoid. Do I have to use special aluminum rivets instead of the ones from Ace Hardware on the belly of my trailer? I would never have suspected that different grades of aluminum could be a problem. My trailer will suffer more wear and tear than galvanic action on rough roads, but it is always a concern.
Thanks for the info, any help is always appreciated.
JimW
Old 12-02-2002, 09:31 PM   #14
LOST , Hawaii
Galvanic reaction is the result of the electrical potential difference in metals, nothing to do with hardness. Brass will generally be softer than steel, but will react with aluminum more than steel does.
Non ferrous stainless will not be as reactive as steel or ferrous stainless. That is why your boat didn't show any sign of corrosion. And you're right, your trailer will suffer more from the roads than the dissimilar metals touching.
John
Old 12-02-2002, 10:01 PM   #15
Thanks John,
That really is an interesting link. I'm still going over it. I find it interesting that low alloy steels are between wrought alloys of the Aluminum 2000 series, and alloys other than the 2000 series. Other than lead, the low alloy steels seem to fit well compared to anything else. Would that not be just plain steel wool? I am getting a bit more confused, but more interested. What alloy is in the Argosy aluminium?
http://www.corrosion-doctors.org/Air...eri-compat.htm
I'm interested in this because of a small amount of frame seperation I have found, I think the fix is the 146 bulletin. Not sure on that yet. It is something I am still looking into. I am sure having fun working on this Argosy. I was wondering what type of bolt to use. Sounds like mild steel is the best in the corrosion department, but what about a stronger bolt of high alloy steel? I'm learning. It will be a while before I'm an aircraft engineer. My launch date is months away, so I'm having fun.
JimW
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
