Old 08-13-2008, 07:55 AM   #1
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Sorting out Argosy 20' years and models
Hi all - I've recently been bouncing back and forth in my trailer search between a 20' Argosy (advantages: cheaper, wrap-around window, more room, lighter, active forum community!) and a newer Bambi 16' (advantages: well, newer, so less repairs likely needed.)
Been reading the brochures and looking at online listings. A few questions about the Argosy:
- Did they sell both Minuets and the "wide-body" 20' models concurrently?
- Did 20' models get the gray water tank (a wife-mandated essential) in 75 with the other models?
- Do only the 77-78 Minuets have the aluminum sandwich floor? I recall an exciting VAP episode where Colin referred to a 75-ish Argosy with such a floor. (Could be a slip of the year.)
So far I've been just missing some trailers that I see listed (including a Minuet in upstate NY - kicking myself over not calling earlier on that one) or finding earlier trailers sans gray tank. Thanks for the info.
mutcth is offline   Reply With Quote
Old 08-13-2008, 09:18 AM   #2
mandolindave's Avatar
It's a tough call
I have a 73 20'. I am close to spending the same amount on my Argosy as a new Bambi would cost. But I now have a customized Argosy fitted with
all the things I needed , and decorated the way I wanted.
mandolindave is offline   Reply With Quote
Old 08-13-2008, 09:32 AM   #3
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
A thought occurs to me (a possibly self serving one, but none the less perhaps still helpful.) A gray tank could be added to an early Argosy. I've seen the threads for it, I just can't find them now.
biggoofball is offline   Reply With Quote
Old 08-13-2008, 10:25 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Our 1972 Argosy 20 had a grey tank added, if you ask him really nice, Bob Fowler may be able to snap a couple of photos of it for you.
Argosy 20 was offered concurrently with Minuets, at least for a time.
Old 08-13-2008, 11:10 AM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I would suggest dropping Kevin (Overlander64) a PM. He is the most knowledgeable person I know when it comes to Argosy info ~
He has a lot of the original brochures & lots of experience in Argosy trivia.
Shari
Old 08-13-2008, 11:17 AM   #6
mutcth's Avatar
2007 23' Safari SE
LOL! Yeah, I know that a tank could be added. But I'm trying pretty hard to buy something where I don't need to pull up the floor or drop the belly pan.
I'm also leaning towards something that could be towed by my wife's Odyssey (I've done the math and it can be done since we leave most of the van's seats empty.) Since the 69-71 Caravel doesn't have a gray tank (and are often pricey), that leaves the 20' Argosy or a newer 16' Bambi. Obviously there are pros and cons to each.
Old 08-13-2008, 11:55 AM   #7
no need to drop the belly pan
Some people added a network of 4" PVC pipe under the trailer and used it as a gray water holding tonk
Old 08-13-2008, 01:24 PM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Based upon the literature that I have, the following may be of help:
  • It appears from literature as well as what I have been able to observe that the Argosy 20 was offered alongside the Minuet 6.0 Metre in 1977 and possibly VERY early in 1978.
  • The first mention of an optional gray water tank for the Argosy line was in the 1973 model year brochures.
  • Early in 1974 the gray water tank was listed as optional, but appears that it may have become standard equipment toward the end of the model year.
  • The gray water tank was a standard feature beginning in 1975.
  • It appears that the Minuet series was the only offering in lengths below 26' in 1979 -- possibly began after mid-year in the 1978 model year.
  • Something to be aware of with the Minuets (at least the 6.0 Metre variety) is that the gray water tank was mounted above the floor level (it is found in the bottom of the streetside rear corner wardrobe), and as such it does not collect the waste water from the shower.
    • An aftermarket solution is to add a small bilge pump to pump the waste water from the shower up to the tank -- it requires driling an access in hole in the wardrobe floor to route the hose and modifying the drain piping above the gray water tank.
  • The most notable difference in interior layout between the Minuet 6.0 Metre and the Argosy 20 when equipped with the front lounge is the presence of a streetside armrest on the lounge in the Argosy 20 while the Minuet doe not receive the armrest.
Kevin
Kevin D. Allen
AIR #827
Old 08-13-2008, 02:00 PM   #9
mutcth's Avatar
2007 23' Safari SE
Kevin, thanks a lot for the details! Other than your posts in the picture pages of the later brochures (which I greatly appreciate), the only brochure I have is for a 73 Argosy.
Can I assume that the gray water tank in the regular Argosy 20' would collect shower drainage, or would that have a similar set-up to the Minuet?
Old 08-13-2008, 02:06 PM   #10
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
I am almost afraid to speculate as the only Argosy 20s that I have direct experience with are 1974 and earlier models that did not have the gray water tanks. I don't believe that the gray water tank was mounted above floor level on any models other than Minuets, but I do not have any direct information to substantiate this as a fact. Hopefully, someone with a 1975 or later Argosy 20 will see this thread and provide a firsthand report.
Kevin
Kevin D. Allen
AIR #827
Old 08-13-2008, 03:35 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
<snip>
Kevin
Told you so!
Old 08-13-2008, 04:09 PM   #12
Well Preserved
1993 21' Sovereign
I know for fact the Argosy 22 and 24 had a below floor level grey tank. I pulled one out of the 1975 parts unit we had. Black tank still above floor, under toilet.
The Argosy 20 we had was retrofitted with a below-floor 10 gallon grey tank. It really wasn't that big a headache to put in, they cut and capped the line to the dump valve, and diverted the grey water into the tank to a separate dump valve.
Old 08-13-2008, 05:44 PM   #13
SnorkyII's Avatar
2004 25' Safari
Escondido , California
Hello Kevin: My 75, 20' parts trailer has the greywater tank, located under the blackwater tank. My 73, 22' does not have a grey water tank.
Regards, SamH
Snorky II
Escondido, CA
ESCAPEES SKP 58345
AIR #13642
04 Safari 25SS, 03 Toyota Tundra
SnorkyII is offline   Reply With Quote
Old 08-13-2008, 08:03 PM   #14
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Kevin
8' Wide 20' Argosy's were made from 1972 - 1976
The Minuete was introduced mid 76 and was made until 1979 it was the only model with the Aluminum Floor.
Grey tanks first appeared in 1974 as a compulsery option. This was how they got around wage a price controls at the time.
1973 Excella 500's also had grey water tanks.
I hope that helps.
A new Bambi is a lot less work and the resale is generally better that an extensively renovated older coach.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Does anyone have the weight info for the different years and models? 72Blazerod General Repair Forum 5 05-01-2008 03:12 PM
Any Years or Models to Avoid? Bonzai30b 2008 Safari SE 4 03-24-2008 08:21 AM
Beatrice Years - Years and Models to Avoid? AndyPenny Buyer Guidelines 7 10-15-2007 11:04 AM
models from previous years bina Trailer Values 8 02-19-2007 09:33 PM
Need your help!What models/years airstream should be our first? airstreamdreamer Our Community 19 11-24-2003 08:51 AM
