Old 10-22-2011, 04:08 PM   #1
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Soft rock guards
I really liked the look of the soft rock guards on SmokelessJoe's gorgeous modernized Argosy24, so I asked him about them. He's been very happy with their performance and ease of installation and removal, so I contacted Hornsby Canvas, the company that made his, and had them make me a set for my Argosy. I really like being able to see all the way through my trailer while towing, and I like the light that comes in through the clear panos so I didn't really want the conventional Airstream rock guards, but I didn't want to crack a pano either. I just got the fasteners put on and here's my Argosy24 with the guards in place:
They seem a bit less smooth than his, but that may be because his are black so ripples don't show as much. Obviously they won't absorb as much of an impact as the smoke-tinted lexan ones, but the most likely highway impacts are smaller rocks kicked up by trucks, not yahoos dropping bricks from overpasses. They're made from Sunbrella canvas, with high-density foam sandwiched between the 2 layers of canvas. They attach with marine-style Common Sense stainless steel fasteners.
For storage (and possibly for camping on really hot Texas summer days) I'm planning to make a cover that goes side to side from Reflectix or something similar that attaches to the Common Sense fasteners.
— David
Old 10-22-2011, 04:14 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Looks great! I'm sure you will tow with less worry now.
Lance
Top is offline   Reply With Quote
Old 09-10-2012, 06:30 PM   #3
1977 Argosy Minuet 6.0 Metre
grapevine , Texas
I like that idea adding to my to do list.thanks. Captn d.
david hh is offline   Reply With Quote
Old 09-20-2012, 07:04 AM   #4
1979 Argosy Minuet 6.0 Metre
Dry Fork , West Virginia
Those look great !!!
I contacted Hornsby Canvas and they said they only have one pattern - for the Argosy 1970-75. Would they fit on my 1979 minuet 6.0???
leherrick is offline   Reply With Quote
Old 09-20-2012, 08:30 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
Yes, they'll fit. The panorama window dimensions are the same, the difference is that the rectangular center window is narrower on the Minuets. Since I didn't even get a cover for the center window (because I like to be able to see through the trailer in the rear-view mirror) the pattern Hornsby made will work. It'll work on later Argosies as well, I'm not sure why they think it stops at '75. For that matter, if you just wanted to cover the panos and not the center pane, it would work on a brand new Airstream as well.
— David
Old 09-20-2012, 09:11 AM   #6
1974 Argosy 28
Contact info
Do you have contact information for this company? Google isnt being helpful on this at the moment. thanks
inTransit is offline   Reply With Quote
Old 09-20-2012, 09:49 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Here is their website, they have contact info on there.
http://www.hornsbycanvas.com/
— David
Old 03-15-2013, 09:36 AM   #8
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
I have purchased a set of these. My question is - what type, size, length of rivet is used to attach the Common Sense Fasteners?
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 03-15-2013, 09:45 AM   #9
DKB_SATX's Avatar
1976 Argosy 28
I had a service company install the fasteners while they were doing some other work, so I'm not sure exactly which rivets they used.
— David
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Rust spots already on rock guards - 2011 Airstream wendywoods Cleaning, Stripping & Polishing 38 03-09-2012 09:34 AM
Poor Man's Rock Guard perryg114 Rock Guards, Segment & Window Protectors 9 10-05-2011 10:15 AM
TAC Illinois Rally - Starved Rock SP - May 13 to May 15 Air Apparent Other Rallies & Events 4 05-14-2011 08:58 AM
Rock Guards on 2005 CCDs jordandvm 2002 - 2005 International 7 11-18-2004 10:02 AM
