Old 08-11-2015, 08:43 PM   #1
1977 Argosy 24
Winston Salem , North Carolina
Side Antenna Replacement
The previous owner of my trailer removed the side radio antenna. I would like to replace it with An original. He left all mounting holes and wires, just covered it with a reflector.
Is this same antenna used on other airstreams or just Argosy?
Anyone else remove theirs and wish to part with it?
Thanks!
WHG423 is offline   Reply With Quote
Old 08-11-2015, 10:21 PM   #2
1974 Argosy 20
Kooskia , Idaho
It used to be a very common antenna and I did some research a year or so ago for someone who needed the same antenna as you do. As I recall I found it at online AutoZone or one of the online auto stores. It is a round base bolt on system with I think 3 holes. The antenna attaches with a split ball arrangement so it can be adjusted and lined up properly. There is a stiff spring at the base of the antenna itself which allows movement in the wind and prevents it from breaking off if snagged. I have one on my '74 Argosy. The same Antenna was used on many Airstreams of the 70's era.
Old 08-11-2015, 10:43 PM   #3
1974 Argosy 20
Kooskia , Idaho
This one from Amazon.com is the same or similar to the original:
Amazon.com : AM/FM Antenna with 96-Inch Cable : Vehicle Audio Video Antennas : Car Electronics
Here is another which may be OK too, but hard to tell from the photo:
Metra Electronics ANTENNAWorks 44US01R - Antenna | O'Reilly Auto Parts
Old 08-12-2015, 06:02 AM   #4
1977 Argosy 24
Thanks! That Amazon one looks nice!
Old 08-12-2015, 06:23 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Stainless CB Antenna Ball Mount with Spring
Old 08-12-2015, 08:32 AM   #6
batman's Avatar
1964 22' Safari
modesto , California
Let's not forget our friends at VTS they have this to offer.
Good luck.
-Dennis
batman is offline   Reply With Quote
Old 08-22-2015, 10:58 AM   #7
1977 Argosy 24
Thanks for the replies guys! I ordered the one mentioned above from Amazon for $24. It's perfect. Got it installed yesterday.
Old 04-25-2018, 03:30 PM   #8
1977 Argosy 28
nunya , Ohio
This is the post I came across while we were looking for an antenna for our 1977 Airstream Argosy and the Amazon link provided above didn't work, so I thought I would provide newer information for 2018
Walmart: $27.99
https://www.walmart.com/ip/AM-FM-Ant...&wl13=&veh=sem
Vintage Trailer Supply: $59.99
http://www.vintagetrailersupply.com/...-p/vts-588.htm
slider007 is offline   Reply With Quote
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Sensar Antenna On Side of Air Conditioner? CA_Tallguy Audio, Video & TV 6 12-06-2012 09:05 PM
'88 Excella side radio antenna dtutko1 General Repair Forum 5 03-05-2012 08:19 AM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
