Old 05-28-2014, 03:04 PM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
Some newer trailers have shower pumps to deal with this problem. Some of these have basins with float switches, some are inline and you just turn them on when needed with a switch.
Old 07-01-2014, 09:23 AM   #16
1978 Argosy Minuet 6.0 Metre
Athens , Georgia
Ahoy!
Thank you all for the info and replies! My thesis work has been sapping all of my time, so I have just gotten back to reading what is here. I looked at the trailer in the shop, and there is a simple shower drain to the outside - no tank. Less weight and more space, I guess? The composting toilet gets rid of much of the space in BW tank, so the toilet will be moved to the side, rather than center-line in the rear.
MIKO92 is offline   Reply With Quote
Old 07-22-2014, 12:53 AM   #17
Athens , Georgia
Hello, again! I have decided to move the GW tank to the space under the oven...since I have gotten rid of the furnace (anyone need one/want one? It's in good shape) and will get a Catalytic heater. My issue now, seems to be having space above the GW tank for the inlet elbow...and keeping some slope on the lav sink drain to get GW there... I'll send pics once the ARGO gets back from the shop.
Thanks to all for the advice!
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Gray Water Tank Instulation and Support Beams??? coairstream Waste Systems, Tanks & Totes 3 10-01-2009 02:54 PM
Gray and Black Water Tank Skycop Waste Systems, Tanks & Totes 9 07-24-2009 06:51 PM
Black and gray water tank Judy Barde Waste Systems, Tanks & Totes 11 12-11-2006 12:43 PM
