Greetings Miss Minn!
Originally Posted by Miss Minn
Hi everyone,
I am confused. Where does the water from the shower drain on the Minuet 6 metre?
J
Unfortunately, at least the 6.0 Metre Minuet and I suspect all of the Minuets, the shower is not plumbed into the wash water collection tank (it is higher than the shower floor as it rests above--actually on--the floor in the rear streetside wardrobe). I believe that the shower drain is connected just behind the dump valve, but this part of the plumbing was changed as was the dump valve on my coach - - it will be good to get back to Thetford quality parts as well as a more near factory original waste water plumbing arrangement (the Valtera valve has been a constant problem).
At this point, I have been discussing alternatives with the dealer's service department who does most of the work on my coaches. The two alternatives that we have been looking at include adding a third tank (second wash water located below the floor for the showerr) or installing a special 12-volt pump designed for use to pump the shower waste in pleasure boats to pump the wash water from the shower up to the standard Minuet wash water tank.
Good luck with your coach!
Kevin
