Old 06-12-2011, 12:09 AM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Scrubbed the paint off
Have an argosy and was a bit aggressive with a stiff brush today while cleaning the winters worth of muck off. I noticed that there are a lot of places where the rivets are bare and shiney now.....What do I need to do now to protect?
Dan
Dan S is offline   Reply With Quote
Old 06-12-2011, 06:31 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Dan!
Dan
In most places on your Minuet you won't need to worry about bare rivets as they are aluminum and won't rust. The aluminum may discolor, but it won't produce rust. If the problem areas are on either of the endcaps, the problem may be a little different as bare metal on the endcap may have been left when the paint popped off of the rivet leaving the potential for rust -- should that be the case, wax would be the bare minimum remedy (a short-term remedy at that) -- touch-up paint would be the longer-term solution if the problem is on the endcaps.
Good luck with your exterior spruce-up!
Kevin
Kevin D. Allen
AIR #827
Sunburn or spray paint? Tabasco Cleaning, Stripping & Polishing 10 05-24-2012 10:01 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 01:19 PM
Airstream 22' New Floors, Head, Tires, Brakes, Paint. eBay Watch Airstreams on eBay 0 04-29-2011 11:20 AM
New Member - more than the paint is not yet dry amuse Member Introductions 1 04-13-2011 08:07 AM
GT Paint Job IronGiant Upholstery, Blinds, Walls & Interior Finishes 0 01-11-2011 10:17 PM
