Old 05-19-2019, 10:45 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Scare/porch light
Mine does not work but ďassumeĒ itís just a burned out bulb.
The lens has three screws which appear to hold the unit into the trailer and provide access. The previous owner must have siliconed the lens. Is as simple as cutting the silicone out and unscrewing?
I ask as the entire unit is held in with rivets.
Dan
Dan S is offline   Reply With Quote
Old 05-20-2019, 07:27 AM   #2
1986 31' Sovereign
Miami , Florida
The three screws will allow you to carefully pry the lens out of the housing. You will find your basic automotive 12vdc socket holding a series 1141 bulb behind it. Hopefully, a new bulb is all you need and you can find them cheap at the auto parts store (or, you can get fancy and go LED.
Personally, I did not seal the lens to the housing when I installed the lamp last time. So far, no water intrusion.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-20-2019, 08:23 AM   #3
richw46's Avatar
Lexington , Kentucky
I recently replaced my bulb and after taking out the 3 screws the lens came out and so did the foam gasket, but the gasket came out in pieces. I couldn't find anyone that sold the gasket so I got some rubber gasket material and made one of my own. I replaced the bulb with an LED. The lens is fashioned so that any condensation can drip out of the bottom, it's open there, no gasket.
I bought this and used the lens as a guide. The rubber is supposed to last a long time.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-20-2019, 09:01 AM   #4
1969 18' Caravel
Greenville , whereEverIroam
LED4RV sells a nice, self-contained LED scare light that is all one, sealed assembly of lens, and LEDs. Simply plug it into the existing socket and screw it back in. And since it is sealed, no water or tiny bugs can get into the assembly and stain the lens. Note it is more expensive than a replacement bulb, but will likely last decades.
http://led4rv.com/catalog/index.php?...roducts_id=549
skyguyscott is offline   Reply With Quote
Old 05-20-2019, 12:08 PM   #5
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
The "Scare light" did not work either on our '76 Argosy. Upon tracing it back (read, replaced lamp and then socket) I found the voltage feeding the switch was less than 12V. I traced it back, as far as I could, finding no loose or corroding connection. I ended up splicing the lead for the door light...Works!
newsgauger is offline   Reply With Quote
Old 05-20-2019, 11:39 PM   #6
Dan S's Avatar
1975 Argosy 26
Thanks all. Iíll let you know how it goes.
HELP. Are you a scare/porch light know it all? algebrotha Lights - Interior & Exterior 29 01-17-2017 10:08 AM
Warm white patio/porch/scare light thomasj Lights - Interior & Exterior 12 11-09-2016 06:58 PM
Porch/Scare Light TDOW 1966 - 1968 Safari 1 05-23-2015 06:08 AM
LED upgrade for Cyclopes Scare Porch Light Dan@LED4RV Commercial Listings 36 08-12-2012 09:24 AM
