Old 09-12-2011, 10:50 AM   #1
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
Rust under clearance lights
I am in the process of taking down all my old non-working clearance lights and have found rust under some of them. I'm not at the point where I want to repaint the whole trailer, but i'd like to take care of this rust issue. I guess I need to sand it down and paint it with something. If anyone has any great ideas, I'd appreciate the help. Thanks
saburkha is offline   Reply With Quote
Old 09-12-2011, 08:36 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I haven't tried it myself, but one of the many notes I've taken from advice on the forums is that Krylon Ivory gloss is a pretty good match to the original color for touch-ups.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 09-12-2011, 10:39 PM   #3
1974 Argosy 20
Kooskia , Idaho
Krylon Dover White is another possibility. It is what I use on my Argosy. I find the Krylon Ivory to be a bit too yellow for my rig. Dover White is available from ACE hardware usually, although the smaller stores might have to order it for you. The Ivory is available at most Wal Marts.
Old 09-13-2011, 06:48 AM   #4
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
You might want to spray some of the rust converting primer on the area before painting with a color coat. NAPA, Pep Boys, etc. are likely sources for the primer. Eastwood makes a rust encapsulator and POR 15 has been used on chassis rust for years.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 09-13-2011, 10:16 AM   #5
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
Thanks guys! The krylon sounds like a great fix for this instance.
« Towing | Top | H e l p »
Top clearance lights on 13 panel whale tail? Sugarfoot Lights - Interior & Exterior 17 08-28-2011 04:01 PM
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
Clearance lights issue jsprad Lights - Interior & Exterior 3 08-20-2011 09:28 AM
Replace clearance lights Okiegent Lights - Interior & Exterior 0 03-04-2011 08:43 PM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
