Old 07-30-2008, 06:57 PM   #1
Boise , Idaho
Run Fridge bypassing univolt
I have a 1975 20er with original Dometic fridge and am wondering if I can rig the fridge to run of 110 directly and by pass the univolt? Anyone
Dman is offline   Reply With Quote
Old 07-30-2008, 07:30 PM   #2
1986 31' Sovereign
Miami , Florida
To the best of my scant knowledge you have to have 12VDC for the control board. You theoretically could bypass the board by running the heater directly to the 120VAC but you would have no temperature control.
You may get away with buying a small 120VAC/12VDC transformer from somewhere like Radio Shack and powering just the reefer control board but why? Is your Univolt dead?
mike
Old 07-30-2008, 08:42 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The standard 2 way (gas/electric) refrigerator of that era does not use 12 volts. When it is on gas, it is only gas. When on electric, it is only 120 volts. The converter is not used in either mode of operation.
Richard
how much propane to run a fridge? Rollerboy Refrigerators 4 10-23-2007 10:50 AM
Will fridge run without battery power? crazylev Refrigerators 9 09-01-2006 01:37 PM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
