Old 11-04-2015, 07:42 PM   #1
1973 Argosy 22
Strasburg , Ohio
Roof ventpipe cover on a '73 Argosy
I'm restoring a 22 ft. 73 Argosy and there are 2 vent pipes that come up through the roof which, after 42 years, apparently became brittle and the tops are busted off. I've removed them and now have a bare black plastic pipe sticking up with a piece of screening over them to keep out the bugs. Since the tops are all busted up, I don't know what they originally looked like. I'm assuming they weren't solid plastic, otherwise the vent pipes couldn't "breathe". Anybody know where I might find suitable replacements? Thanks!
Tree Tapper is offline   Reply With Quote
Old 11-04-2015, 07:51 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
You could put plastic back up there, but many of us have switched to aluminum. See this thread, starting at post six. You do need to call but hopefully they are still available !
http://www.airforums.com/forums/f478...ers-89212.html
reinergirl is offline   Reply With Quote
Old 11-04-2015, 07:56 PM   #3
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
The original parts where just plastic versions of the cast metal pieces that Airstream was using at the time. You can buy the cast metal vents from several different vendors and paint them. Or do what I did and buy the vintage looking caps. No one makes the plastic version, that I have been able to find
Here are the metal cast ones.
Aluminum Vent Pipe Cover
And the cheaper vintage looking.
Metal Roof Pipe Cover
Damon
#4827
damonbeals is offline   Reply With Quote
Old 11-06-2015, 07:30 AM   #4
1973 Argosy 22
Strasburg , Ohio
Thanks for the information! I have two new caps on order!
To cover or not to cover? steveirving Winterizing, Storage, Carports & Covers 9 07-28-2014 07:31 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
Cover or not to Cover? Sixty3TW4US Winterizing, Storage, Carports & Covers 7 09-16-2008 12:08 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 07:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
