Old 08-21-2016, 09:01 PM   #1
1976 Argosy 26
Henderson , Kentucky
Images: 14
Roof vent -Where can you buy
Need to replace to old plastic roof vents for plumbing. Can't find. Anyone know where to find.
Ky76Argosy is offline   Reply With Quote
Old 08-21-2016, 09:49 PM   #2
1976 Argosy 26
Fair Oaks , California
Is this it ?
You will also need the gasket .
http://www.vintagetrailersupply.com/...p/vts-1081.htm
Argosy Heir is offline   Reply With Quote
Old 08-22-2016, 05:46 PM   #3
1976 Argosy 26
Images: 14
elusive Plastic roof vent
Nope close but no cigar. that's an expensive metal vent. Replacement roof vent I am trying to find is that type but my original is plastic.
Old 08-22-2016, 11:06 PM   #4
1976 Argosy 26
I think the plastic version was Argosy only and I am certain they are no longer available .
If you want something less expensive you can use this type . It actually is a better vent cover and does not really look out of place once painted to match the trailer .
http://www.vintagetrailersupply.com/...-p/vts-517.htm
Old 08-23-2016, 08:12 PM   #5
1976 Argosy 26
Images: 14
Roof Vent blues
That's one fine renovation, only dream my 76 with queen middle fold out gaucho will be any thing close to that beautiful job. Yep thought your response is the answer. But if going to paint would plastic screw down type work equal well?
Old 08-23-2016, 09:52 PM   #6
1976 Argosy 26
The plastic would be ok short term. If painted it would certainly help with the UV protection. Again, they are plastic so the base eventually would split where the screw secures it to the trailer. If you have an RV supplier near by they might stock metal covers . Thanks for the compliments !
Change a metal roof vent by a transparent roof vent ? GaŽl Roof Vents, Skylights & Fans 11 12-27-2014 05:55 PM
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
