Old 02-20-2015, 09:26 AM   #1
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
Roll up cabinets
I have a 1976 Argosy 26' with the roll up cabinets. Most of the are hard to push up. Others will not stay up. The one under the sink that goes sideway s is almost impossible to move. Does anyone have any experience repairing these? Any advice would help.
coolbabe is offline   Reply With Quote
Old 02-20-2015, 09:54 AM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Those are Tambour doors that over time become very hard to open and close due to the door material deteriorating and hanging up in the door track. Ther are many threads on the subject of repairing, refurbishing and replacing the old Tambour doors. It is a project any way you go for sure. On my 1976 Sovereign I tried several methods to repair the old Tambour on the the door below the kitchen sink, Microwave compartment next to fridge and the TV cabinet. None worked and all looked bad. I was able to refurbish the Tambour overhead cabinet doors since they were made with a different Tambour material and after paining they look and work fine. I completely redid the other cabinets and replaced the old Tambour with new custom oak doors and a custom made oak roll top door for the old Microwave compartment. I also redid the counter top and other things as well over the years. Pictures are included in the attached pdf file. Good luck. Post some pics we would like to see what you have and your progress.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 02-20-2015, 10:49 AM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi, In my End cap rejuvenation thread I touched on how I repaired my stuck and stiff tambours. Silicon spray will be very helpful to get them moving but most likely your problem is likely a combo of dirt in the tracks and the threads from the fabric backing on the tambours jamming the movement. (Think of when a thread gets caught in a zipper) If you get them out give the fabric backing a shaving with a razor knife it clear off any loose threads.
http://www.airforums.com/forums/f39/...ly-124989.html
thesignlady is offline   Reply With Quote
Old 02-21-2015, 07:51 AM   #4
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Lift up on the front edge of the under sink tambour as you try to open it. The tambour gets more flexible with age and tends to bind on those long doors. I've found that lifting up as I pull the door back (or push it forward to close it) makes it work well when the tracks are clear. There should be some 'slop' in the fit of these doors to the track so the door should be able to move up a little as you lift it. If it doesn't lift up a little, there may be dirt in the track or the track may have shifted. Lifting up as you open may free it enough to make it easy to open. Same with lifting as you close it. As for the not staying up, the tracks get old and the catches get rounded or broken. I have not found a source for new tracks for the upper cabinets, at least for the cabinets that are rounded in front.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 02-21-2015, 09:13 AM   #5
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
I like the look of those period Tambours so much that I ordered enough to make
3ea of 2 door model from Airstream Parts but be warned it was stupid
expensive for just the lower handle aluminum handle, the plastic end caps and roller mechanism...but the worst was the actual wood and fabric backing pcs. Even though
they claimed I would get the upper and lower 1/4 round aluminum extrusion they
never came through with it and now I'll have to make them out of wood.
ADNOH: love your interior.
Del Gurney is offline   Reply With Quote
Old 12-12-2017, 07:11 PM   #6
coolbabe's Avatar
1976 Argosy 26
That is superior. Gave me several ideas. Thank you
Old 12-20-2017, 09:03 AM   #7
Argonaut20's Avatar
1966 17' Caravel
VTS had tracks for the overhead tambours for a while. The tracks crack and split so new ones make the doors work MUCH better. They stay up and open smoothly.
2006 Toyota Tacoma
roll top cabinets RHINOEGG Cabinets, Counter Tops & Furnishings 1 08-31-2010 04:53 PM
Blue Beltline Insert - $13. for 50' roll COArgosy78 Commercial Listings 8 08-09-2003 09:54 PM
storage area roll-doors Wolf Cabinets, Counter Tops & Furnishings 3 08-01-2003 05:56 PM
Roll up doors [tampor] ? niftypkg Cabinets, Counter Tops & Furnishings 5 05-17-2002 07:23 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
