Old 09-10-2005, 08:53 PM   #1
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Rockguard installation on Argosy Minuet
This has been posted elsewhere on the forums - but here is a detailed (pics and all) set of Rockguard mounting instructions for an Argosy Minuet.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-10-2005, 09:00 PM   #2
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
OK - well there seems to be an error message opening the file in the previous post - we'll work on it. I guess we're still in the testing phase!
Old 09-11-2005, 08:39 PM   #3
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
I just downloaded the file and it worked. Can some other members please try and post your results?
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 09-11-2005, 08:45 PM   #4
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Thumbs down Ok!
It was good for me!
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 09-11-2005, 08:54 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Andy!
I am running Windows XP Professional with the full Adobe Acrobat 5.0 package, and when I download the file (I am on a DSL Internet connection) I am getting an error message as follows: "Error reading linearized hint data".
Kevin
Kevin D. Allen
AIR #827
Old 09-11-2005, 09:05 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
works for me
adobe 6.0 on dsl
john
you call them ferrets, i call them weasels.
Old 09-11-2005, 09:20 PM   #7
Not for Adobe 5.0
Tried again. I have Adobe 5.0 Professional. Been meaning to update it to 6.0 Professional. I use my company laptop so I have access to Adobe Acrobat Pro.
I get the error: "Error reading linearized data".
Anon is offline   Reply With Quote
Old 09-11-2005, 10:35 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Rivet
I've done the Service Pack 2 biz and run Firefox -- the latter being source of trouble on certain websites. But I had no trouble opening this .pdf file and have the simple Acrobat Reader only -- can't even say I've done any updates lately.
The original link still works of course... An invaluable item on these forums if you ask me!!!
5 meter Langford Nahanni
Old 09-11-2005, 11:54 PM   #9
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
The pdf was created in adobe 5. I run XP on one machine and 2000 on another - both with adobe 5. I get the same error message. But - i can read the file - saved on my hard drive. i mounted the file on my own website (very breifly) and was able to download...suggestions?
Old 09-12-2005, 01:54 PM   #10
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
It looks like that has something to do with the Acrobat plugin and the way it optimizes the bites for quick viewing in your browser.
Here is a fix I found for this:
http://www.royalmouldings.com/Pages/AdobeHelp.htm
Why do I get "Error reading linearized hint data" when I try to open a PDF file using Adobe Acrobat Reader 5?
If you are using Internet Explorer or Netscape to go to a URL containing a PDF file, you may get an error message, "Error reading linearized hint data" when you try to open some PDF files using Adobe Acrobat Reader. You can correct this problem in Adobe Acrobat Reader 5 by doing the following: Open the Adobe Acrobat Reader, click Edit, click Preferences, click General (if required), click Options, uncheck "Allow Fast Web View.", and click OK to save the changes.
Why do I get "Error reading linearized hint data" when I try to open a PDF file using Adobe Acrobat Reader 6?
If you are using Internet Explorer or Netscape to go to a URL containing a PDF file, you may get an error message, "Error reading linearized hint data" when you try to open some PDF files using Adobe Acrobat Reader. You can correct this problem in Adobe Acrobat Reader 6 by doing the following: Open the Adobe Acrobat Reader, click Edit, click Preferences, select "Internet" in the table on the left, uncheck "Allow Fast Web View.", and click OK to save the changes.
Old 09-12-2005, 02:13 PM   #11
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
The recommended fix worked! Wahoo - something went right!
Old 11-08-2005, 08:32 AM   #12
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Thanks Janet. Excellent info. I've saved a copy.
Moonshot is offline   Reply With Quote
Old 01-20-2006, 01:51 AM   #13
Hippo's Avatar
Battle Ground , Washington
Janet,
I have a question. I was looking at a 1974 Argosy Trailer 27 foot. Would you know which model it would be?
Chuck
Hippo is offline   Reply With Quote
Old 01-20-2006, 10:17 AM   #14
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
Chuck, There are two distinctly different argosy's from the seventies, Argosy and Argosy Minuet. The minuets were made in 77 - 79 and were narrower than standard Argosy. If the one you're looking at is a 74 it is a standard Argosy - the same width as an Airstream of that vintage...
The lenght of record is measured from bumper to ball... For floor plans, check out Overlander64 photo albulm. He has great documentation of the argosy line!
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 05:42 PM
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 10:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 10:13 PM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 08:51 PM
Front Window Rockguard themartaman Windows & Screens 3 07-14-2002 12:01 PM
