Old 02-02-2008, 01:15 PM   #15
1975 Argosy 22 Rear Door
TV is '99 Range Rover 4.6HSE , California
Pictures of shattered window (finally!)
Had the guy at the storage place snap these pics. It looks like the frame is fine and just the window and seals need to be replaced. Given the frame is in good shape, it seems like I could get the plexiglass replaced if it was done by a good shop - any comments versus replacing the frame + window with something that's airstream authentic?
Nice to see she's stored in a dry and safe place at least, but we're itching to get her home!
Thanks!!!
Steve
ID:	53573   Click image for larger version
1975 22' Argosy Rear Door
Towed By: 1999 Range Rover 4.6HSE (fulltime 4x4)
mendosoft is offline   Reply With Quote
Old 02-02-2008, 01:29 PM   #16
Thanks!!!
Steve
Steve.
Plexiglass cracks and crazes in 30 to 60 days, which weakens it. It was not designed to take sun light, ever.
More importantly, the thickness of any plastic that you can use is 1/8 inch.
That size plastic, when hit with air currents, will flex and blow out.
Remember, if the trailer is going 60 mph and you meet a large vehicle coming towards you at 60 mph, the resultant wind speed is 120 mph, far more than needed to blow the window out.
You can, however, if you wish to use plastic for a wrap window, install a rock guard over the front three windows, but that costs over $600.00 by itself.
Unfortunately, there is no cheap solution to replacement of a broken wrap window.
Also, today, they are only available in solar gray.
Old 02-02-2008, 01:38 PM   #17
Thanks again, Andy...
Yeah, I hear your points exactly, and if it wasn't for the issue of not having a clear window rather than the tint, I'd have already ordered a replacement from you most likely. I'm kind of stuck on the 'clear window' look being maintained, so that's my first preference if it's possible somehow. If not, then we'll go with the factory replacement w/tint.
Too bad Airstream doesn't have any subcontractors who make replacement parts to give the marketplace some more options (clear/tint, whatever). It seems like someone could make decent $$ manufacturing replacement parts most commonly needed.
Great forum, thanks a lot to everybody!
Old 02-02-2008, 07:36 PM   #18
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
alternatives
what about lexan or acrylic? i know some of them are uv proof and can be bent. don't know about strength vs. thickness?
" If everything is working, something is wrong ! "
crowbar68 is offline   Reply With Quote
Old 02-02-2008, 07:40 PM   #19
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Check out Out-of-Doors Mart
they have the side wing windows for 70's AS, but I do not remember if they have the wrap around for Argosy's. They also have "sunglasses" on sale right now.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 02-04-2008, 07:25 AM   #20
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Has anyone heard if a front bra type protector over the windows and lower front section would work if padded to protect from rocks & stones? The canvas shop in my area said that they have made lots of stone/rock guards for RV's and trucks that work very well. They also suggested to use SS snaps to install and remove the bra quickly. Price quoted is @ $300.00
Argy 78 is offline   Reply With Quote
Old 02-04-2008, 07:48 AM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
You could go through a lot of work with this idea and have a cover that still would let a window-breaking rock deliver enough impact to damage through the canvas. I saw one similar picture on AIR Forums years ago. I thought it through for my Argosy and decided that it was more cosmetic than real protection -- and I think that's half the reason I've never seen it used more often. They used twist studs which I think would be more reliable than snaps:
Image from this site -- I'm not seeing them at West Marine any more. This requires the oblong grommets of course. I'd only want to use such a device if I could rivet and avoid using screws. With a dab of Sikaflex 221 around the rivets of course.
5 meter Langford Nahanni
Old 02-04-2008, 08:53 AM   #22
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
My Argosy has these snaps riveted in... They look pretty O.E. to me... I found a source at a sail shop online... just have to buy the Sunbrella fabric and sew away. I think a cover with a small layer of foam inside would work. I've been debating making one with a clear layer of vinyl in the center to preserve my ability to look back when driving. That's the number one reason why I haven't purchased the solar shades.
Marc
Old 02-04-2008, 10:13 AM   #23
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
That's what I did with my Overlander. I used a 1/8" clear Lexan that is UV rated. Lowes happened to have a left over scrap piece that was just about the size I needed. Only charged $15.00 for it. I would have loved to replace with OEM glass, but just couldn't afford it.
www.nesa.org
Air No. 6427
72 Safari Removing Banana Wrap in front of battery compartment Tom Bray Belly Pans & Banana Wraps 2 08-27-2007 11:55 AM
Replacing damaged banana wrap panabax Belly Pans & Banana Wraps 5 04-28-2007 05:40 AM
1975 Argosy front window Happycampers Windows & Screens 9 11-03-2005 07:51 PM
Wrap around windows - front and rear? SilverToy Off Topic Forum 5 11-01-2005 11:55 PM
front wrap-around windows Daryl Windows & Screens 6 11-28-2003 08:29 AM
