Old 10-10-2013, 05:05 PM   #15
1979 Argosy 27
Fort Fairfield , Maine
PEX is the way to go! Pre planning, as stated, use brass fittings when available, also stated. A hint: After a fitting is crimped it can still be turned as when needing to screw it in a pipe fitting. Sometimes this is the easiest way and seems to be without any problems in doing so. Buy your crimps and major fittings such as elbows in bulk bags, a lot cheaper.
Stumpjumper is offline   Reply With Quote
