Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 03-28-2007, 11:09 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Replacement speakers
Has anyone removed the four stock speakers in their Argosy and replaced with better ones? I'm curious if there is a thin (assuming they are thin) modern speaker that would improve the sound?
I'll check crutchfield.com out but would like feedback from those that have done this.
Dan
Dan S is offline   Reply With Quote
Old 03-28-2007, 11:33 PM   #2
Killo1's Avatar
2005 22' Safari
Santa Ana , California
Dan,
Not to familiar with the Argosy speaker cavities but I do know that you can get spacers if you see speakers that are deaper than the depth you have.
Here is a link for the type of product I'm thinking of.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Old 03-29-2007, 08:23 AM   #3
Dan S's Avatar
1975 Argosy 26
Speakers
Thanks for the info on spacer rings. However, I want to keep it "looking" as original as possible while upgrading those items that are hidden or critical to the operation/safety.....speakers are obviously critical-ha !
Dan
Old 03-29-2007, 08:59 AM   #4
Retired.
. , At Large
I think they are 6" round speakers. Check into marine speakers, they will resist the moisture in our trailers better than automotive speakers.
Old 03-29-2007, 09:24 AM   #5
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
You also might want to check out Parts Express
http://www.parts-express.com
I am currently working on some custom portable speakers to use outdoors with my Ipod to replace my 3 dollar Sony speakers.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 03-29-2007, 10:46 AM   #6
Retired.
. , At Large
Magnadyne Aquavibe WR65T Tan 6 1/2" Coaxial (pair) Waterproof Marine Speakers
Details:
Designed to endure the harsh elements of the outdoor environment. Aquavibe speakers incorporate high quality components with design to imporve sound and resist the wear and tear associated with wet weather. These rugged and reliable speakers are built to withstand rust, corrosion and warping. They can easily withstand the hosing down of your deck or splash from overside.
FEATURES:
- 12 oz. magnet weight
- Waterproof polypropylene woofer cone
- 2" waterproof mylar tweeter with Ferrofluid
- 50 watts maximum power handling each speaker
- 4 ohm impedance
- 65Hz-18kHz frequency response
- 87 dB
- 2-1/2" mounting depth
- Grill diameter 7", Cutout diameter 5 1/4"
- Ideal for all outdoor uses
- Full plastic encasement frame and integrated grill
- Resists moisture, temperature and shock
Old 04-05-2007, 08:02 PM   #7
Dan S's Avatar
1975 Argosy 26
8-Trac help
Everything was going great until one of the tapes started warbling.....of course, I smacked it and now the player stopped working. Radio is fine, but no groovy 8-trac.
Any suggestions?
Dan
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
