Old 08-04-2006, 12:11 PM   #1
1975 20' Argosy 20
Portland , Oregon
Replacement exterior vinyl striping
I'm looking for a supplier for the upper vinyl stripping that goes around my'75 Argosy. Any suggetions? thankyou. padraic
Padraic is offline   Reply With Quote
Old 08-04-2006, 12:46 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi again Pat -- You're talking about the orange inserts?
Take a look at Vinyl side strips for '76 26' Argosy and Looking for Beltline. Installation technique is discussed...
If you don't go with Sutton RV I can strongly recommend prices and mail service from Tucson's Oasis RV. Their parts dept does a great job over the phone and they've tended to have this item when others haven't.
5 meter Langford Nahanni
Old 08-04-2006, 12:48 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Have you called Airstream?
If it is the 1" or 1/2" colored strip around below the windows, Airstream had a number of rolls in different widths and colors at Salem in their mobile parts and service dept... I'd try calling them, though it would have to be ordered through a locla dealer.
If that fails, you might also have luck searching through old threads looking for vinyl or molding or strip...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-04-2006, 05:25 PM   #4
We have that material.
Old 11-13-2006, 08:30 AM   #5
sierrajb's Avatar
Arlington , Texas
Yes, Andy, but do you have it in orange for the Argosy? I have been told Inland only carries the blue for silver Airstreams, not orange for Argosy Airstreams. Am I wrong?
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
Old 11-13-2006, 09:58 AM   #6
We have had and will have all the different sizes of "orange" belt line and rub rail inserts for the trailers as well as the motorhomes.
Old 11-13-2006, 10:15 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
From my analysis the material is not vinyl. It is polyethylene, and from my experience with the factory material, it is very poorly stabilized for UV resistance.
Old 11-13-2006, 12:00 PM   #8
All Airstreams vinyl insert is made with "vinyl."
There is one exception and that is for the narrow blue insert which is made from polyurethane.
This is per Airstream Parts department as of today November 13, 2007.
Old 11-13-2006, 01:29 PM   #9
sierrajb's Avatar
Arlington , Texas
Thanks, Andy, for the clarification. Must have picked up some inaccurate info somewhere.
For others looking for the ORANGE...I just got off the phone with Justin of SW Coaches (1-949-551-6179). They also can get both sizes of the orange vinyl insert for the Argosy at a GREAT price as of today, Nov. 13, 2006:
Part #201417 (1/2") Orange beltline is 12 cents/foot.
Part #201418 (1 1/2) Oranges beltline is 29 cents/foot.
Some good prices to compare with other dealers. I think I might give Justin a call. Shipping will be only what it costs for Airstream to ship it to him. Not a bad deal at all!
Old 11-13-2006, 01:48 PM   #10
Shipping from Airstream has a "BIG IF."
"If" the dealers cost is less than $100.00 for the shipment, then Airstream has a $10.00 handling charge, "plus" the shipping.
Changes the complexion of things, and true costs, quickly.
Old 11-13-2006, 02:03 PM   #11
Part # 201418 is for rub rail insert for a motorhome, not a trailer.
Old 11-14-2006, 11:20 PM   #12
sierrajb's Avatar
Arlington , Texas
Very true, Andy, as usual.
Be sure the dealer can include your small order of insert in a larger order from Airstream. This takes care of that handling charge from Airstream, leaving you with only the cost of shipping from the dealer to your house. If you live in the same town as that dealer, then no shipping cost at all.
I have a lady in my town who owns a 75 Argosy motorhome. It turns out her rubrail is the same size and configuration as the lower (larger) rubrail on my 75 Argosy trailer. Even though the part number may show "motorhome" the application will most likely work with a trailer. At least, in my case it will. WHEW!
Aren't Airstreams wonderful?
Old 11-16-2006, 08:15 AM   #13
coldbigred's Avatar
Arlington , Texas
Andy,
Like sierrajb, I'm cornfused. In a post dated 10/2002 you said the "only color available is blue"...
...the only color available is blue and in 50 foot rolls only.
You can find them in our parts sale list of our website (inlandrv.com) as part numbers 70494, 70506 and 70530.
Then, in the post above, you told sierrajb "We have had and will have all the different sizes of "orange" belt line and rub rail inserts for the trailers as well as the motorhomes.
I can see why the confusion. Perhaps you are referring to the blue for silver Airstreams, and the orange for painted Airstreams (Argosy)? Either way, the bottom line (pun intended) is that BOTH colors are out there (same sizes, by the way), but the blue will be much easier to locate than the orange.
My two bits, for what they're worth.
coldbigred is offline   Reply With Quote
Old 11-16-2006, 09:18 AM   #14
Originally Posted by coldbigred
Andy,
The orange vinyl inserts were discontinued by Airstream, back in 2002.
Airstream, by popular demand, decided to bring it back into inventory about a year or so ago.
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
