Old 01-13-2019, 12:19 PM   #1
First time Argosy owner
Pharanak's Avatar
1973 Argosy 24
Plantersville , Texas
Replace entire subfloor?
Hey all!
We’ve gotten our Argosy completely gutted and now begins the arduous task of making her livable again.
At present the subfloor is primary concern, there’s holes in the corners, and a little separation up front.
Judging from the photos would you say I should replace the entire subfloor or just patch things here and there?
The top three pics are of the front.
Bottom two are back of trailer.
There seems to be no issues in between.
Thanks in advance!
-phrank
ID:	331596   Click image for larger version
ID:	331598   Click image for larger version
Pharanak is offline   Reply With Quote
Old 01-13-2019, 12:30 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
IMHO, you have leaks and they may have, but most likely will not have been found and sealed yet.
I found with my subfloor repair that in most cases the top 1/6th of plywood looked strong and dry, but found the rest below was wet and or dry rotted.
You may, or most likely be facing residual or future black mold issue if you don't take it out and replace it.
I would take the subfloor completely out, giving you a chance to assess the frame below, fix any issues with outriggers and PQR-15 the frame. I would then replace the subfloor with Coosa board; 40-45% lighter than plywood, just as strong, if not stronger; will not rot, promote mildew or the growth of mold and fungus; less than 1% water absorption; which means you don't ever care about leaks ever again, (unless the leak lands on your bed).
Cheers
Sidekick Tony
PS My subfloor repair
http://www.airforums.com/forums/f311...me-106269.html
PSS It's a lot of work, yes, but so is the rest of your project; why not start the process properly and do it right from the beginning. A future owner will appreciate it, and so will your bank account, should you decide to sell the Argosy.
Old 01-14-2019, 10:22 AM   #3
Pharanak's Avatar
1973 Argosy 24
Yo sidekick!
That’s some very good advice
Very much appreciated!
Old 01-14-2019, 12:20 PM   #4
1981 31' Excella II
New Market , Alabama
The front and back areas are the most important. This is where the hold down plates are. I would recommend you remove the lower skins at least some of it and see what the frame looks like. You need to get all the wet pink fiberglass out. Most of us POR 15 the frame and make spot repairs. Your floor does not look that bad. I would say replace the front and rear sections. The rot in the corners are because the C-channel has a gap in it where the straight walls meet the curved sections. You will want to pull the lower inner skins and get the soaked fiberglass out of there as well. It is also the best way to find leaks. I ended up putting drains in my C-channel to keep the water off the floor and funnel it under the trailer. Unless you find some really rotten frame members, I am not sure I would do a shell off. Also you don't need to replace axles as the first thing you do which seems to be the advice on here.
Once you start pulling stuff apart you will understand the structure a little better. Also you will save some time by keeping wiring and plumbing, and electrical like they are instead and trying to reinvent the wheel. You can get over your head quick by doing a total gut then have to figure out how to make it a trailer again.
Perry
Old 01-15-2019, 06:41 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Been there done that. Like Tony said above. Once I got started it was quite easy. Best thing I ever did was to replace it all and get rid of all those nasty smells.
Old 01-19-2019, 11:57 AM   #6
Pharanak's Avatar
1973 Argosy 24
Perry
Good points Perry!
I will try to maintain the current electrical skeleton, I like the idea of keeping what ain’t broke.
Also, will get into the skins and removal of insulation in troubled areas. That’s a good bit of advice!!
Old 01-19-2019, 12:00 PM   #7
Pharanak's Avatar
1973 Argosy 24
Ahhh the stink! It has definitely motivated us to get the entire trailer redone.... seeing as we’ve removed every bit of furniture/cabinetry/bathroom inside and it still hasn’t become perfectly neutral smelling!
Old 01-20-2019, 06:08 PM   #8
Eric 26 Argo's Avatar
Knoxville , TN
I to would say Sidekick Tony's advice is very good. I pretty much did exactly what he said with the exception of the Coosa board. It was a little too expensive for this camper. I found that once the floor was up I had to replace all the outriggers on the Curbside and the floor looked better on that side.
Eric 26 Argo is offline   Reply With Quote
Old 01-21-2019, 09:24 AM   #9
1981 31' Excella II
Even with plywood these things will outlast most of us. Think about where you are going to be in 30-40 yrs when the floor needs replacing again and that is assuming it was neglected like the first time. Unless you want to be buried in it, (stranger things have happened) does it need to be way better than it was? Mine has been since 2011 and I have had no real problems other than a leak around the door frame that was taken care of with par bond. I put some drains in my C-channel to keep the water off the floor.
Perry
Old 01-21-2019, 12:23 PM   #10
1969 18' Caravel
Greenville , whereEverIroam
Never underestimate water, mold and bugs
Some may indeed get by with reinstalling plywood with no problems and save a few hundred dollars.
After having the factory redo the subfloor in both the front and rear of my Caravel after purchase about 12 years ago, (they reinstalled plywood) the subfloor at the door and around the fridge and wheel well needed replaced last year. If I had done the whole floor in Coosa board the first time, I would have been money, time and hassle ahead.
To me, it's more than worth the hundreds of dollars extra for the Coosa board because in addition to being virtually water proof (and the water comes from leaks, spills, plumbing issues, intrusion, condensation, and so on and on) the floor is lighter in weight, mold resistant, critter proof, bug proof, won't warp or rot or do any of the nasty stuff plywood always does. So what if it outlasts me, I won't ever have to redo it ever again, which is the main point.
skyguyscott is offline   Reply With Quote
Patch or replace entire panel? caitpdx Ribs, Skins & Rivets 7 11-14-2015 09:17 PM
entire 1991 airstream 34' excella the entire trailer all parts EVERYTHING woodmon8 Airstream Classifieds 1 03-13-2015 12:45 PM
Replace entire roof, am I crazy? Brian Schulz Ribs, Skins & Rivets 7 06-21-2014 11:02 PM
Entire Y assembly and dump valves FELL OFF! dalefox Classic Motorhomes 7 10-23-2008 01:52 PM
Entire Contents Of A 1967 Vintage Airstream - $100 SaabLover Interior Restoration Forum 4 03-18-2007 01:44 PM
