09-07-2014, 08:33 AM
Eckville, Lacombe County
, Alberta
Refrigerator access panel, vented or not?
I just noticed this on a site selling RV parts. They sell a vented exterior refrigerator access hatch. Mine is a regular access hatch.
Should it be vented?
Whats yours?
I doubt the trailer makes a difference but mine is a 76 28ft with a fridge and freezer compartment.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
09-07-2014, 08:35 AM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
If you have a refer vent in the floor behind the refer, you don't need the vented door.
Lance
09-07-2014, 09:24 AM
, Alberta
Its vented through the roof. So I guess thats good enough?
Oh, I think I get it now. If its not vented out the roof it likely needs to be vented out back or via the floor.
TAC AB-1
09-07-2014, 09:54 AM
Always learning
1972 29' Ambassador
Central
You must have two vents for proper airflow. One down low (intake), either a hole cut in the sub-floor and belly pan (typical for mid 60s to mid 70s) or the vented access door, and one up high (exhaust), typically a roof vent or another vented access door.
Lance
09-07-2014, 10:07 AM
, Alberta
Nothing in the floor, thats for sure, so perhaps I do need a vented door then.
Top, whilst I have your expertise here, perhaps you could also whey in on this thread I just started
http://www.airforums.com/forums/f425...ml#post1507311
TAC AB-1
09-07-2014, 10:13 AM
Always learning
1972 29' Ambassador
Central
Originally Posted by Bex
Follow Lewster's advice and you'll not be led astray.
Lance
09-08-2014, 08:55 PM
1977 Argosy 24
Milltown
, Wisconsin
A 76 Argosy should have a vent through the floor at the back of the fridge. Also a vent on the roof connected to the top of the fridge with a plastic chase that can be seen from the inside directly above the fridge.
09-08-2014, 09:18 PM
1974 Argosy 20
Kooskia
, Idaho
Yes, open your lower access door and you should see a hole in the floor with 1/4" hardware cloth over it (for critter control). Below that, in the belly pan, another hole with more hardware cloth covering it. I hope some PO has not covered them up. If so, uncover them.
09-14-2014, 11:29 AM
, Alberta
Its there. funny, when you dont look, you dont see, even though I looked at it a dozen or so times when I had the hatch open!. Shined a flashlight from underneath and its all good and open.
TAC AB-1
09-18-2014, 10:41 PM
1977 Argosy 28
Euless
Refrigerator vents.
Hole in the floor is good! Several experienced airstream owners have told me that some of the ones with the vented door have problems with the pilot light blowing out.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Vented Refrigerator Access Panel Lost
mello mike |
Exterior Storage Compartments & Access Doors |
2 |
02-13-2011 09:56 AM |
Vented Cat Heater
Old Nuke |
Furnaces, Heaters, Fireplaces & Air Conditioning |
8 |
10-22-2010 10:08 AM |
vented battery box
toastie |
Batteries, Univolts, Converters & Inverters |
6 |
11-14-2008 11:00 AM |
Vented Battery Box
Neophyte |
Electrical - Systems, Generators, Batteries & Solar |
16 |
05-19-2006 07:04 PM |
