Old 11-02-2005, 07:57 PM   #1
MontanaArgy's Avatar
1976 Argosy 20
Helena , Montana
Send a message via AIM to MontanaArgy Send a message via Yahoo to MontanaArgy
Rear Storage Compartment collects water.....
and nicely channels it directly into the belly pan. It looks like it is designed this way. Originally it had gaps on each end into the bumper shell and the ends of the bumper acted as scoops and gathered rocks, dirt and water into the compartment. I've plugged these off. I think the leak is now mainly through the hinge along the lid. I've tried Andy's method of window hinge sealing with silicone which he recommends for some of the older trailer windows. It has helped lots, but still getting water in, and into the belly pan. Anobody else have this problem? Scott.
MontanaArgy is offline   Reply With Quote
Old 11-03-2005, 05:39 AM   #2
Alden Miller's Avatar
1993 34' Excella
, Maryland
Yes, I have a nice water collector at the back of my AS also. I haven't seen it traveling into the belly pan yet though. I was thinking my problem was because the back bumper is slightly bent. I have the bumper removed now and I am going to work on straightening it this winter.
Maybe I should figure out a way to install some small drains at the bottom of the compartment to redirect the water out past the belly pan.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 11-03-2005, 07:37 AM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Hey guys, I've got the same problem in my '73. The base problem is that there is no way to seal the storage compartment. A buddy of mine told me about some flat, one way drains used in the aviation industry. When I get to that point I'll try them out. Then try to figure out a way to seal the compartment better.
Below is a pic of the damage caused by the water leaking in and traveling into the belly pan. Look closely at the bottom on the "I" beam.
www.nesa.org
Air No. 6427
Old 11-03-2005, 11:28 AM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have a MH, not a trailer so I don't really what your storage compartment door is like. I had a lot of trouble with leakage in the storage compartment doors and slide out storage bins. I finally found some stuff to seal these. If you have pictures I could see if I think the stuff I got would work.
guy99 is offline   Reply With Quote
no water remcolent Fresh Water Systems 3 04-16-2004 01:05 PM
Water proofing Rob Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-31-2002 09:37 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
