Old 06-02-2007, 12:30 PM   #85
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
sandwich style?
Gary, cost may be an issue, but would the signboard stufff that boatdoc used on this Argy work? I believe it is metal sandwiching wood?
Marc
Old 06-02-2007, 01:06 PM   #86
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by Janet's Husband
I just measured it and the thickest plywood I could use is 17/32". I was hoping to go a little thicker to get the floor stiffer.
Hi Gary -- When I replied earlier I ran downstairs to take a look at the stamp on my plywood stock. I've only replaced the front section of floor though I also have to do under the bathroom. I did have to replace a floor section under my battery but haven't had to deal with inserting floor in this type of channel. Trying to go stiffer than the 1/2" ply I settled on 19/32" CDX underlayment (more complete inner veneers than other building grade plywoods, though not perfect!). Marine ply is supposed to have the most complete veneers but I couldn't get my hands on any.
I haven't done the following but I've been thinking. (Danger!) The bottom veneer in any panel will be vital to maintaining the stiffness against deflection under load; the top veneer is in compression only. If you want floor stock that's more than 1/2", here is a straightforward solution that's better than attacking plywood with a belt sander to make it fit. And it doesn't need to be fitted over every frame member because the underside stays flat!
Tack a temporary fence parallel to the floor edge so that a router could hog out the extra few 32nds of an inch. Start from the outside edge, moving progressively toward the fence for the amount that has to go into the channel. Your front and back C-channel can't sit at a different level, so rip a thin stringer that be used as a fence to follow that curve to let you inlay the C-channel into this slight reduction. Try it on a piece of scrap first to fit into the channel as you set your router bit depth. This slight extra floor height might need some thinking through how it will affect the door entry and putting the same partitions back in. I'd seal the edges plenty good with Rot Doctor, though that's a whole different topic. Plenty to think through alright!
5 meter Langford Nahanni
Old 06-02-2007, 01:31 PM   #87
Notice on the old ply at the curved ends. On my '74 there wasn't a screw hole through every hole in the C-channel -- the empty holes had a corresponding ramping of the floor top edge with a rat tail file as if they intended these to drain water in the C-channel outward and discharge along the inside of the banana wrap.
Old 06-02-2007, 04:41 PM   #88
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
That makes sense, any water caught in the C-channel would drain out. I wondered what the of the extra holes in the channels were for. I'll file the ply, then do the edge treatment. I think your previous post will work, the only thing I can figure would be different would be the C-channel would ride up on the uncut portion of the plywood. This would cause a slight shift in the holes for the extrusion, which I think would be a good thing. Fresh holes for the pop rivits.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 06-02-2007, 04:44 PM   #89
1964 26' Overlander
1977 25' Tradewind
Marc
I looked into that stuff and I think it is beyond my Peter Principle and price range. Good thought though, keep em coming.
Peace
Gary
Old 06-02-2007, 04:51 PM   #90
1964 26' Overlander
1977 25' Tradewind
Polyethylene vs. ABS Tanks
I need some new tanks for the project, fresh,grey and black. I was wondering if ABS tanks have improved in the recent past or are they still prone to cracking. ABS is lots cheaper than polyethylene, but not if you have to repair and replace them.
I'm looking for input on this subject. I'll be ordering them in the next few weeks and I need to hear from you all on this subject.
Peace
Gary
Old 06-03-2007, 06:48 PM   #91
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
I bought polyethylene for the black water replacement I needed. Frankly, I wanted (and got) strength. I have no wish to try ABS for the tanks.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 06-05-2007, 09:21 PM   #92
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
If the tanks are exposed at all I'd avoid ABS. While picking up my gray ABS tank (an inside under counter tank) there were three tanks in the shipment to the parts store. Mine was the only one that did not need repair before the RV parts guy could sell them. Scary.
Barry
safari57 is offline   Reply With Quote
Old 06-24-2007, 05:01 PM   #93
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Images: 90
Garys been busy! The shell and frame are seperated. The floor leaves something to be desired....
Name:	trailer chassis 1.jpg
ID:	39809   Click image for larger version
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-24-2007, 05:12 PM   #94
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Someone once told me that they weren't doing a shell off. hmmm.....wonder who that was.......
Lookin' good ! Looks like they went with the cheap stuff when they put that floor in at the factory. Lots of knots there. (read voids)
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 06-24-2007, 05:15 PM   #95
Janet H's Avatar
1964 26' Overlander
Images: 90
All the wood and mouse infested insulation is taken out and the rust kill is applied. No frame cracks. But... also no frame support across the front and back. This explains the spongy feel in the floor in those areas. We will add a couple of chunks of c channel in these areas.
ID:	39811   Click image for larger version
Old 06-24-2007, 05:18 PM   #96
Janet H's Avatar
1964 26' Overlander
Images: 90
well um.... that person is now practicing hard to be flexible....
There was not one square inch of insulation that wasn't full of mouse trails. we never would have gotten the smell out.
Old 06-24-2007, 05:24 PM   #97
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
LOL
There was not one square inch of insulation that wasn't full of mouse trails. we never would have gotten the smell out.[/
I hear ya. It is the reason I had to do it to mine.
Project 2k5
Old 06-24-2007, 05:40 PM   #98
1975 Argosy 26
1963 24' Tradewind
looks like a yard sale on that plywood... how many cordless drills and jigsaws did it take? LOL! How did the shell come off, was it supported from the outside and the floor driven out?
I helped move a 64 Safari and 70's 24ft Argosy today. What a difference in weight. Maybe the lack of c-channel is how they saved some weight... and money? I loved looking at that 60's trailer in my rear view mirror...... must resist!
All that insulation is really gross. Makes me cringe about mine. Yuk!
Marc
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
