06-24-2007, 09:40 PM
#101
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern
Originally Posted by overlander63
Gary, IIRC, the black tank partly extends through the floor in the rear of the trailer, it would be a good idea to make sure where it goes before adding the C channel back there. The old grey tank went somewhere around that area, too. Are y'all going to move the tanks to a more central location?
I have decided to keep the tanks where they are currently located, grey tank under the floor in the rear and the black inside in the back, fresh in front. It would be really difficult to change them due to the space available in the frame and I want to use this trailer in cold weather. The grey tank has an insulated box and a heater duct routed to it. I will be reinforceing the frame at the grey tank and at the front where the spare tire carrier would be. I found these two spots to be real soft without reinforcment under the plywood. I plan on adding a couple of outriggers to add stiffness under the shower curbside and the street side. I have also been looking at increaseing the thickness of the floor and I think I could go up to 5/8" from the stock 1/2" without too much trouble. I really dislike flabby floors.
Peace
Gary
06-24-2007, 09:55 PM
#102
1975 Argosy 26
1963 24' Tradewind
Seattle
so no bigger tanks Gary? I can't remember exactly how big that grey tank is.... feels like only 10 gallons or so. I think my blue tank is bigger! I kind of like the ability of taking just the blue tank to the dump station, instead of the whole trailer.
The black should be big enough... we can JUST get 3 days for 4 people out of it. I wish it was deeper though... we seem to have some temporary mountains grow in the morning that don't float away fast enough for four people in the mornings.... which makes it seem liket the tank is full, when it's not really. I'd like to make a "shaker" for it to uh, distribute the "loads" better. Sometimes I have to go outside and find a stick to make it all fit ok. TMI, I'm sure!
Oh yeah, my point is, the black tank should be fine as is.
Can't wait to see more!
Marc
06-24-2007, 10:06 PM
#103
1964 26' Overlander
1977 25' Tradewind
Eastern
Marc
We checked the grey tank and it is 15 gallons not really big, but we are used to the Minuet and it is 7 gallons. We have found the black tank will last us for about 4 or 5 days, I can't see us needing any more than that.
Peace
Gary
06-27-2007, 08:02 AM
#104
1963 16' Bambi
Yreka
Gary and Janet, Shell off restoration. Wow. I've been there and done that! It's a lot of work. However you will be very pleased with your trailer when it's done. Nothing like a new classic. It's looking good.
Don & Claudia
09-22-2007, 08:42 PM
#105
1964 26' Overlander
1977 25' Tradewind
Eastern
Touch Down
OK The shell is now back on the frame.
I used Reflectix foil bubble, spaced out 1" using pink closed cell foam for the insulation. The floor is 1/2" marine ply sealed on the bottom and edges with Cabot sealer. I then used foil tape to seal the Reflectix to the plywwod edges and then rolled it up over the top of the wood. It worked out pretty well I think. I was pleasently suprised how easy it was to mate the shell with the frame. I used a floor jack to lower it from the saw horses and move it around.
I figure I still have 20 hours of work left to get the banana wraps and trim back in place. Lots of rivets.
Tomorrow, I'm planning on putting the new axles on. THat is my last bit of work until after the BB Bash IV. Sorry no pictures, I was just too busy.
Peace
Gary
09-22-2007, 11:52 PM
#106
1975 Argosy 26
1963 24' Tradewind
Seattle
Whew! Let's see... shell ON, Axles ON.... hmmmm... can we say "ROAD TRIP!"... come on... it'll be tent camping at the finest for BB! : >
Can't wait to see you guys - safe driving!
Marc
11-08-2007, 06:16 PM
#107
1964 26' Overlander
1977 25' Tradewind
Eastern
Door Rivets
OK
Here I am with a roll of aluminum, a Rivet Squeezer and No rivets.
As some of you know I am in the middle of changing the direction the door opens and installing a new lock assembly. In order to do this I have to re-skin the door. I am in need of the rivets used on the perimeter of the door. I know they are braizer head rivets but I don't know the size to get the correct head diameter. I ordered AN470's from Airparts but the heads are way to small.
I need the size and a source for them. Any Ideas?
Peace
Gary
11-08-2007, 06:55 PM
#108
gunnyusmc
Livingston
Door Rivets
Call David at Roger William Airstream 800-378-5883.
He rebuilt my Argosy Door after it blew open.
Gunny
11-08-2007, 07:07 PM
#109
1971 21' Globetrotter
Arvada
Originally Posted by Janet's Husband
OK
The correct P/N is MS20470AD5-X with X being the lenght in 1/16ths. To get the right length, add the total thickness of the mat'l being riveted then add an additional 1.5 rivet diameters. I get My rivets here Genuine Aircraft Hardware Co.
11-08-2007, 08:58 PM
#110
1964 26' Overlander
1977 25' Tradewind
Eastern
Great Place, I just ordered three sizes of rivets and a bunch of #21 and #30 Cobalt drill bits.
Thanks Muchly
Peace
Gary
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Rear bath mirror!
niftypkg |
General Interior Topics |
1 |
04-10-2007 08:52 PM |
Saggy Bottom ( rear end )
smily |
Repairing/Replacing Floor &/or Frame |
127 |
10-01-2006 08:28 PM |
Leak in the rear
JodynJeep |
Sinks, Showers & Toilets |
10 |
09-08-2006 09:40 AM |
