Old 07-13-2014, 03:37 PM   #15
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
You know, it's not like the water is standing in the hose leaching flavours & pollution from the rubber. It goes through the hose to fill the tank and that's all. It ought to be OK.
Gearheart is offline   Reply With Quote
Old 07-13-2014, 04:26 PM   #16
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
I used ribbed pool hose from the big box store.
Bill
cosmos is offline   Reply With Quote
Old 07-13-2014, 04:34 PM   #17
helmsman's Avatar
1967 22' Safari
Long Beach , California
Hello Savage68:
I've used a radiator hose in that position (for more than 40 years), longer than the original hose lasted.
Rick Davis and Gearhart are correct. The only time that radiator hose comes into contact with the fresh tank water is when it's being filled. A few seconds at most. I too have not had any taste transferred from using the radiator hose as a filler hose.
When I was new to airstream trailering two members of the club had contracted Giardia from filling their tanks while passing through a small town, but that wasn't caused by using a radiator hose as the filler hose.
helmsman is offline   Reply With Quote
Old 07-13-2014, 06:59 PM   #18
r carl's Avatar
Lin , Ne
You should be able to form a clear vinyl hose with a heat gun.
Old 07-13-2014, 07:19 PM   #19
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Have used radiator and heater hoses for a variety of things including drinking water applications over the last fifty years with no problems ever encountered .
dannydimitt is offline   Reply With Quote
Old 07-14-2014, 07:43 AM   #20
Originally Posted by helmsman View Post
Hello Savage68:
Not exactly.
When the trailer is in motion, the water splashes into the filler hose.
But, to each his own.
Old 07-14-2014, 09:27 AM   #21
Zil
egg harbor city , South Jersey
The radiator hose will last forever. Flush it well before putting on your tank. it will be ok for you. Don't let little children drink the water, they are more sensitive to the bad stuff.
Zil is offline   Reply With Quote
Old 07-14-2014, 10:25 AM   #22
Ottawa , ON
from BoatUS archives:
Potable Water Hose
Special Needs: Chemically inert. Hoses that carry drinking water have to be made of FDA approved nontoxic materials (stamped on the hose) so that chemicals from the hose don’t leach into the water; the chemicals also make the water taste bad. PVC hose is usually used for this purpose and systems that have pumps to deliver water under pressure or have hot water should use a reinforced type.
While many potable water hoses are clear, opaque hose has the advantage of preventing slime from forming. Even clear hose that is hidden behind lockers will eventually get growth inside. Once slime gets started, it can be killed by allowing a bleach solution (three-quarters of a cup per 10 gallons) to remain inside for a few minutes, but getting the residue out is nearly impossible without removing the hose and running a rag through it.
As Andy said though, the choice is yours.
Old 07-16-2014, 09:25 AM   #23
jcampana's Avatar
1974 Argosy 24
San Diego , California
I've seen people use the flexible hose for pool vacuums before. That might be another alternative.
jcampana is offline   Reply With Quote
Top radiator hose pvmsteve Land Yacht/Legacy Motorhomes 7 10-11-2016 10:48 AM
Argosy started leaking near input of hose susans69 Plumbing - Systems & Fixtures 22 06-01-2012 06:48 AM
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
1975 Argosy 350 cu.in. lower radiator hose source needed 911rs Argosy Motorhomes 8 08-18-2008 10:59 AM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 09:20 PM
