Old 06-24-2010, 12:35 AM   #1
1979 30' Argosy
saint augustine , Florida
quick "spot" fix for flecking paint?
someday......i will totally repaint my argosy. but TODAY i want to simply spot treat some troubled areas above the front windows where the paint has flecked off. any suggestions would be helpful.
happypill is offline   Reply With Quote
Old 06-28-2010, 06:42 PM   #2
The front and rear caps are not aluminum.
They are steel that was galvanized.
The only fix, is to strip the paint on those 2 caps, treat the galvanized metal with a mild acid, clean it up, paint it with a very good primer, wait a day or 2 and then color coat it.
Or, leave it alone.
Spot painting it will do nothing, since corrosion is the cause of the "flecking".
removing leak "fix" of PO (tar) obxairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-17-2008 05:33 PM
Fire(s) after the Dometic "fix"?? Kistler Refrigerators 1 08-11-2007 06:25 PM
Fix that "wrong" battery reading meter!! lebolewis Batteries, Univolts, Converters & Inverters 6 06-24-2006 07:44 AM
How can I fix "yellowed" bath fixtures? Wynne General Interior Topics 8 09-09-2004 08:50 PM
