Old 03-23-2009, 08:58 AM   #1
campman's Avatar
1979 Argosy Minuet 6.0 Metre
JACKSON , Mississippi
Send a message via Skype™ to campman
Question: Lubrication for Reese stablizers/levelers??
For my Reese stablizers/levelers that have been used a fair bit, can anyone tell me about any LUBRICATION that may be required? I do note that the "shoe" where it fits into the sling at the back has the original surface worn. They do work fine, but at times there is a large amount of 'squeaking' and 'complaining' back there. I'd call Reese, but it appears they have no telephone service, which I find strange. Thanks, Dan
Dan in Mississippi, formerly of Ohio, New Hampshire, Alaska, New York and New Guinea...among others.....
From Paul Theroux: ..the difference between a traveler and a tourist is.."travelers don't know where they're going, and tourists don't know where they've been"
campman is offline   Reply With Quote
Old 03-23-2009, 09:09 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I've had my instructions around somewhere... I recall it says you can use a bit of petroleum jelly to reduce the noise only. Do not use grease. Lessening friction in that way defeats the function of the cam antisway.
I've found that mine are making less noise as time goes on. Yes, they do wear significantly. My Safari isn't here so I can't run out and verify -- my impression is that some heavy tools could allow a person to flip the studs right to left and upside down to get a new surface. Anybody done that? How much is too much wear and when should that be done? Are there replacement studs available? All fair questions to answer at some time. I'm not seeing any urgency to do it now.
5 meter Langford Nahanni
Old 03-23-2009, 09:14 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Reese is now owned by TriMas Corp. They do go out of there way to protect there phone number and shield themselves from the public but this will get you there. 248-631-5450
As for lub. You can oil or grease the trunions and there sockets of the hitch head. You can use Vaseline on the saddles at the ends of the bars.
2004 Excursion 4x4
Old 03-23-2009, 09:37 AM   #4
Ahh, that's right. Thanks! Look at the spring bars where they fit in the hitch head. A dab of lube on each of the shiny spots is recommended.
Grease the ball too. You'll hate this advice for what it'll do to clothing.
Old 03-23-2009, 04:31 PM   #5
campman's Avatar
Goodness!!! It never fails: have a question on your mind for a few days or weeks and then ask the Forum!!! Bingo! You get the answer right now. Thanks a lot for your help and for the Forum!!
Dan
Hensley hitch lubrication Brian Hobin Hitches, Couplers & Balls 11 02-11-2009 06:24 AM
Reese WD Hitch Question usa448 Tow Vehicles 10 09-01-2008 08:54 PM
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 02:59 AM
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 05:08 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
