Old 04-13-2012, 10:15 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Pump fitting leak !
Replaced the old non functioning flowjet quiet quad with the sure flow whisper king, huge decrease in noise. However, I can't seem to get a seal on the outgoing end of the pump. The 1/2 plastic fitting the screws onto the pump has a barb fitting that in turn connects to the hose keeps leaking.
I've clamped it, put two on actually and it keeps leaking. I can't seem to find a barb that starts of larger and narrows so when I push the hose on it increasingly snugs up. All the fittings have barbed ends that are just one size.
I'm tempted to replace the entire rubber hose portion but not sure what type to use as the one on the trailer says cold use only and all hose at Home depot says hot water use for dishwashers.
Any ideas, thanks.
Dan
Dan S is offline   Reply With Quote
Old 04-13-2012, 11:34 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Sounds like the hose you are using may be old or original. If used before on the old pump then it may have indentations on the inside that have not sprung back prevnting a tight seal and that allows the water to leak. I would also look to replace the plastic barb fitting with a brass or even better satinless steel fitting from HD or Lowes. Do the same for the hose clamp - go SS. The hose replacement is also at HD or Lowes - bulk tygon hose - get the stuff with nylon fibers inside the clear tubing - sold in bulk it's not all that expensive by foot. All this is in the plumbing section. Sometimes they have cut pieces that are discounted and you can cut your own and have some as backup. Put some teflon tape on the threads of the barb fiting that screws to the pump housing for insurance. Length of hose and new fitting would probably set you back less tha $20 and last a long long time.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-14-2012, 07:15 AM   #3
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Ditto clancy_boy's comments.
As a quick test, and if you have enough of the original hose to spare, you could snip off an inch or so and remake the connection, the indents as discussed above, will be gone. Also, you can get, for want of a better term, double wrapped hose clamps, and these allow a much tighter fit than a single which can begin to thread strip before getting tight enough.
It might also (unlikely, but possible) be that you need to back off the pressure shut off adjusting screw so that the pump shuts down sooner, and under less pressure.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 04-15-2012, 11:49 AM   #4
Dan S's Avatar
1975 Argosy 26
After 4 trips to three different hardware stores, and several hoses, couplings, barbs etc, it seems to be fixed.
The difference between the whisper king pump and the old flowjet is amazing. Reminds me of the difference between the old style generator db ratings and a Honda eu2000 !
Thanks for the suggestions.
Dan
Should check valve leak a little? KYAirstream Plumbing - Systems & Fixtures 7 11-04-2012 10:09 AM
Pex fitting leak - toilet supply line eberrobw Sinks, Showers & Toilets 9 04-13-2012 09:55 AM
Leak from AC heat pump housing danlehosky Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-22-2011 10:44 AM
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
