I turned on the propane tanks last night after losing power I can't smell but I was told my trailer was, and all around, had a heavy propane smell. After airing it out and opening the tanks back up the odor was coming from the oven.
If your oven is like mine, turning gas on to the stove will put gas on at the oven. There are a couple things you can do. One, you can light the ovens pilot light. Two there is an adjustment screw under the stoves cover that can be used to cut off all gas to the oven pilot. Good luck.
__________________ "If a man does not have an ideal and try to live up to it, then he becomes a mean, base and sordid creature, no matter how successful." Letter to his son Kermit, quoted in Theodore Roosevelt by Joseph Bucklin Bishop, 1915
Just to clarify.....the smell isn't a slight one....it's immediate and in large quantaties as if there is a major leak. I had used the trailer a month ago and no one had commented on a propane smell. All I have done since then is park it in the driveway. Could something have punctured a line within the oven or broken the pilot in the the oven?
Just to clarify.....the smell isn't a slight smell....it's immediate and in large quantaties as if there is a major leak.
Given some time you will get that from what I described. You may want to check the lines to make sure there isnt a catastrophic failure somewhere but I will bet money that if you let it air out and start the pilot you wont have the smell. Im not a tech, but I went through a similar episode.
I think you were editing while I was responding. Make sure there is no major leak. Then try what I suggested.
Just to clarify.....I had used the trailer a month ago...All I have done since then is park it in the driveway....
Hi Dan, I am curious, did you use the oven/stove on your last trip?
Glad to see you will be safe rather than sorry. With these old trailers we run many risks with the components having bounced down the road for 30+ years. Water pipes leak and circuit breakers blow, but the gas system has to have the most potential for disaster, injury or death
Steve
__________________ Have you never questioned those who travel?
Have you paid no regard to their accounts- Job 21:29
No I did not use either on the last trip. However, I had the furnace on and other people in the trailer that would have smelt the propane. Additionally, had it been leaking like it is now I'm sure it would have blown.
I now have a propane sniffer so I'll open up the lines and put it right on the oven controls under the stovetop where the controls are and then go to the piolt in the oven itself.
So....if I don't light the pilot and and an hour goes by before I decide to turn on a stovetop burner the trailer would explode....I think there's that much coming out. Again, I 've used the trailer many times and the smell was never there......?
Dan
Dan, Absolutely!!! Do Not Light Any Pilot Lights!!!! Propane is heavy and will be stronger smelling in any confined spaces (like under the floor), (in the oven), or (within cabinets where lines may be running.) It sounds as if you may have a line leak (split in the line tubing) or a fitting or elbow leak that the pressure from your regulator is allowing the gas and fumes to escape from, and that is what you are smelling. It Is A Explosion Hazard! Trace your gas lines and check them and all fittings including shutoff valves with soapy water or bubbles. Find ALL leaks and repair them before you light any of your pilots!!!! Use the Propane bottle shut off valve to eliminate one bottle and only turn the other bottle on to test where you have soaped the line or fittings! Let any smell inside the trailer air out before a second test so you don't build up fumes inside as any spark or electric switch arc could become a disaster! You can call a propane dealer to see if they will check the lines etc or take the trailer to any A'S or other RV shop. Be Safe and find all the leaks and you can sleep soundly on your next trip. Wheither it's camped out or just in the driveway you'll know everything is safe and good to go! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT FORUMS MEMBER SINCE 12/16/2004 AIR#7110
"My tire was thumping, I thought it was flat! When I looked at the tire... I noticed your CAT!" Burma Shave
Dan, I'd invest in a good Co2 detector after you find your leak..hopefully you'll hear it if there is a problem if you do not have neighbors close by to rely on their senses. That could have gotten real ugly if they hadn't given you a heads up. Good luck...
