Old 09-09-2015, 08:56 PM   #1
1973 Argosy 20
San Diego , California
Potable Water Drain Valve
My potable water drain valve is stuck shut (beats being stuck open I guess).
Kind of a PITA to have to use the pump to flush the 30g tank every year.
I ordered a new one from OoDM. It has two NPT thread sizes and looks like it just screws in.
The old valve is buried in a mass of plumber's putty. I assume once I remove the putty the valve should just unscrew? What are the odds of cracking the tank bung? I think I'd rather live with a stuck valve than have to replace the tank...
merlinj79 is offline   Reply With Quote
Old 09-09-2015, 09:11 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Home made tool, good leverage without twisting the valve off,
MICHAEL
Old 09-09-2015, 10:00 PM   #3
Mission , Texas
Old plumbers putty is sometimes not real fun to loosen. I'd use the biggest wrenches the space will allow and settle for completely taking the drain line apart if need be.
Reassemble with teflon tape.
nrgtrakr is offline   Reply With Quote
Old 09-10-2015, 07:59 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Just what I did.....
.......I used one of these to prevent it EVER breaking again.....
Then attached a 1/4" ball valve for easy opening & closing.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-10-2015, 02:00 PM   #5
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
___________________
Now that is a fix it job! I like it. Too bad I paid JC to put a new one in after I twisted the top of the plastic one off. Spectacular!
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 09-10-2015, 04:35 PM   #6
1973 Argosy 20
Thanks, that was the failure mode, the thin plastic handle sheared off.
I thought about going with real plumbing hardware but the old one lasted for 42 years and I stumbled on the plastic replacement while ordering something else. Also I'm less likely to strip the tank bung with plastic (I hope).
Old 09-10-2015, 04:49 PM   #7
AWCHIEF's Avatar
Images: 33
Bob, nice fix. I think you are set for life on that one.
MICHAEL
Potable water tank drain 94 Excella CBWELL Fresh Water Systems 4 10-09-2014 03:41 PM
Potable water tank drain annie oakley Waste Systems, Tanks & Totes 1 05-26-2009 04:17 PM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
