Old 08-31-2009, 02:46 PM   #1
lascassas_camper
Apache_Camp's Avatar
1975 Argosy 24
Gatlinburg , Tennessee
Porch light
I can't seem to get my outside porch light to work. I replaced the whole exterior part, housing, bulb, bulb holder and all. The switch by the door appears to be "on". Theres no current to the light. All the other lights 12/110 seem to be working correctly. Any thoughts?
Apache_Camp is offline   Reply With Quote
Old 08-31-2009, 03:43 PM   #2
Kevin245's Avatar
A/C,
Could be a number of things. First thing I'd do is test the circuit to see if there actually is power to and from the switch. Could be a bad switch, then I'd look at the bulb and maybe the ground.
Best of luck,
Kevin
Eleanor Roosevelt
Old 08-31-2009, 04:21 PM   #3
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I agree with Kevin. Start on the back side of the switch to make sure the power is getting that far. If it is to the switch, then check the "out" side of the switch. If you have power there as well, you know it's the wire to the fixture. I don't know if the porch light has the connection inside the wall by the light (as the running lights do)
Alwhisman is offline   Reply With Quote
Old 08-31-2009, 06:03 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I've had to replace 2 of those switches in my '73. After a while, they just stop working...probably the contacts corrode, or something. anyway, there's no taking them apart to see what's wrong inside. and they don't make an exact replacement for the originals, either.
anyway, nobody said it yet, so I will: don't forget to check the fuses, first.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-09-2009, 10:46 PM   #5
MontanaArgy's Avatar
1976 Argosy 20
Helena , Montana
Send a message via AIM to MontanaArgy Send a message via Yahoo to MontanaArgy
Mee too!
I am having the same problem with my porch light too. I was even showing 12+ volts and the light wouldn't light. Finally had wires (both pink) pulled as far as they would go, traced up to the vent and to the front reading lights. Get 12V but not enough amperage to light a bulb - tough to figure. I can run 12 volts from somewhere else to the switch and the light works. The joint has apparently gone bad somewhere I can't reach it. I tried threading a new wire in, and just couldn't get anything to quite connect where I could get a wire hooked to it to pull. I finally put it all back together for now. May have to surface mount a new wire on the inside wall and put one of those wire covers on it unless I can figure out how to get another source of power there. Otherwise have to pull the interior skin, don't want to do that!
Otherwise may just put one of those LED self powered units there for now. I really miss the porch light!
I would suggest you run a good source of 12v to the switch and see if that doesn't make your light work, just to see if it is a corroded high resistance connection.
By the way, take those switches which stop working and soak them in alcohol or similar overnight, it usually cleans them out and they are good as new.
MontanaArgy is offline   Reply With Quote
Old 09-12-2009, 07:29 PM   #6
lascassas_camper
1975 Argosy 24
My switch had been painted over and needed replacing anyway, so I ordered 2 off ebay. The fit perfectly and had the same style clips on the back as my Argosy. Unfortunately my Univolt just bit the dust, so i haven't had a chance to see if it fixed the problem yet.
*1975 Argosy-Airstream 24
*1995 Palamino Mustang Popup Camper
*1996 Buick RM Wagon 5.7L V8, AT/OD, tow pkge, coil over shocks, hitch, brake box, cooler.
*Good Sam Club Life Member
Old 09-12-2009, 09:56 PM   #7
lascassas_camper
1975 Argosy 24
Try these, they fit perfectly in my Argosy.
2 on-off RV Light Switch Motor Home Camper Marine 12 v:eBay Motors (item 370225162730 end time Oct-03-09 10:34:19 PDT)
Porch light cleaning GlenCoombe Lights - Interior & Exterior 10 06-30-2013 02:16 PM
Porch Light Placement toddster Lights - Interior & Exterior 8 12-27-2008 05:18 PM
LED Porch Light RLS Lights - Interior & Exterior 11 09-18-2008 11:19 AM
Porch light for sale azfiredog300 Roof Vents, Skylights & Fans 50 02-11-2008 11:09 PM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
