Old 01-19-2006, 10:05 AM   #1
princeton , New Jersey
Please tell me how to go about painting
Hi-- I have no idea what to do!! I need to paint the front top of my 1973 argosy!!! How do I scrape the old paint??? With what tool??? Then what?? do i prime it??? how big a job is this?? how long should it take?? Thank you for any guidance you can give me!!!!
suze9234 is offline   Reply With Quote
Old 01-19-2006, 12:03 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Have a 78 Argosy that I have done lots of touch-up painting on. You cannot tell the difference from the old paint and what I have done as far as color. I will tell you what has worked for me. I use an electric sander with medium grit, then fine grit to feather the edges, wash the trailer with Por-15's Marine Clean, rinse very very well, let dry, tape off everything I don't want painted. Then I put several thin coats of Krylon "Ivory Gloss" in the spray can on the trailer. Test to see if this color matches yours. It is a perfect match for mine. I have done extensive painting on the end caps, the dings on the front and the top. It has stayed on there with no problems for almost 14 months of hot Oklahoma Summers and cold winters. I gave this information to someone else here on the forum and it worked for them too.
ID:	17772   Click image for larger version
juel is offline   Reply With Quote
Old 01-19-2006, 03:11 PM   #3
Thank you!!!!! I appreciate it very much! Your argosy looks great!
Old 05-23-2006, 11:29 AM   #4
argosy75's Avatar
1975 Argosy 24
Graham , Washington
Images: 32
Thanks for the painting tip.
argosy75 is offline   Reply With Quote
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 02:35 AM
Painting Walls of Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 13 04-19-2010 02:25 PM
Refurbished International Plates tenrsingr Clearcoat, Exterior Paint & Trim 12 08-11-2005 06:31 PM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 04:32 PM
Painting the "tongue" of a trailer... Andy R Clearcoat, Exterior Paint & Trim 17 05-03-2002 02:55 PM
