Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-21-2014, 09:34 AM   #1
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Panel sizes, Minuet to "regular" Argosy
I looked at a Minuet at the weekend. The front and rear 1/4 panels (front/rear curved) are all dented badly due to vandalism.
I have a bunch of original A/S panels that I know would fit my 28ft because I offered them up as a template and they are a match. Is a Minuet narrower? Or is it just shorter? Seems like a lot of trouble to go to to make completely different panels for a Minuet.
If I knew the panels were good, I would buy it.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 07-21-2014, 05:07 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Minuets are narrower. The quarter panels MAY be the same and the difference in width MAY be the center panel width. Sounds like you need to do some measuring.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-21-2014, 05:24 PM   #3
Bex
I felt it was more likely to be the center panel that would make the difference because the windows are the same as well, so that would mean the same profile curve....wouldn't it?
TAC AB-1
Old 07-22-2014, 02:57 PM   #4
Argonaut20's Avatar
1966 17' Caravel
Sounds like the center panel is the key.
2006 Toyota Tacoma
Old 07-23-2014, 10:56 PM   #5
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
either way you could just cut the panel smaller to fit. quick fix is just pull the dent and use aluminum body filler.
AlbertaBound is offline   Reply With Quote
Old 07-28-2014, 06:11 AM   #6
Bex
Its the curved panels so I am not sure that would work entirely satisfactorily but Its of no consequence now. I passed on the purchase. I remembered what the odour was in the trailer. Dead mouse. No way I want to start pulling panels just to find a mouse or ten.
TAC AB-1
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
argosy vs regular airstream ??? Small Fry All Argosy Trailers 19 06-23-2009 06:05 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
