Old 03-19-2014, 09:26 PM   #1
1973 Argosy 22
Shepherdsville , Kentucky
Painting
I've been reading, on other forums, about people painting their small trailers with foam rollers and brushes. Has anyone here painted their Argosy this way? If so how did it look? Tom
Tom S is offline   Reply With Quote
Old 03-19-2014, 10:03 PM   #2
ArgosyRover's Avatar
Hello Tom,
I'm just undertaking a roll on paint job on my 24' Argosy.
I'll be documenting it on my blog and an upcoming YouTube series.
Many people have painted with rollers, some with very good results.
What I can tell you is,...
Finish -
If you want a smooth spray like finish you'll have to roll many very thin coats wet sanding between. It's a lot of work.
If you can live with a slight pebble texture you can just roll on two or three thinned coats.
Paint -
Most use Rustoleum, but it's a bit soft and very slow to dry thus picking up lots of airborne debris. I use Japan Drier to speed drying and harden the paint which will preserve the shine.
Prep -
As with all paint jobs, it's all about the prep.
Just make sure you prime any bare aluminium with a good primer for aluminium.
Ideally zinc chromate.
Good luck.
I'm prepping now, should roll the top half in a day or so.
Cheers
Peter
ArgosyRover is offline   Reply With Quote
Old 03-19-2014, 10:05 PM   #3
1974 Argosy 20
Kooskia , Idaho
Somewhere there is a post on that subject. It was several years ago. Try the search function to see what you can locate.
I have used Rattle Can spray paint on my Argosy with quite good results. It takes a lot of cans, but even so, the price is much cheaper than a professional auto repair shop would charge. Lots and lots of thin coats is the key. Krylon has been the paint I have used the most.
Old 03-19-2014, 10:17 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Painting
Industrial Imron (3500 HG) can be rolled or brushed and is reasonably priced at about 100 a gallon inclusive of activator.
I have used Rusoleum with hardener, pretty good stuff, but even with hardener it won't "kick" if left in a sealed container even for weeks or months. (In other words the hardener won't cure the paint, I don't think it really works)
The Imron seems expensive, but the coverage is phenomenal. I say roughly twice the coverage of Rustoleum, and it lays down and flows out super nice.
I would sand to about a 320 grit finish for a brush paint job, you might get away with 280 with a light color.
When you sand make sure to hit the edges well, and take note a good sander will make the rivets very flat very quickly.
Old 03-19-2014, 10:31 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Peter , are you still able to get zinc chromate primer?
I haven't seen it in a few years, and the last etching primer I bought no longer has Zinc chromate,
( I can smell that stuff just thinking about it. It reeks.)
Old 03-19-2014, 10:50 PM   #6
I don't think so.
I'm Canadian, and I can't get it there.
I'm refitting my coach while travelling and am currently in New Orleans and a local shop had an industry only Chromate System etch primer from Dupont.
I don't know if it actually had zinc chromate in it but he's had great success with aluminium Land Rovers so I'm confident.
Cheers
Peter
Old 03-19-2014, 11:45 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I have painted a lot of aluminum, my experience has been that so long as it is sanded well and has plenty of "tooth" to hold the paint, the paint will stick well, although I still use a thin coat on important paint jobs.
I use DuPont products as well, I still have a little bit of the old stuff with zinc chromate, but I am pretty sure they have ceased production as of a couple a few years ago. But I reserve the right to be wrong about that,,,,
Old 03-20-2014, 07:50 AM   #8
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I cannot immediately find the thread but there is a very informative (its pretty much the definitive) thread on rolling an Argosy. Its by boatdoc. I have to leave right now otherwise I would find and post the thread link.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 03-20-2014, 07:57 AM   #9
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Originally Posted by ArgosyRover View Post
I don't think so.
Cheers
Peter
We use 2 part epoxy primer from ppg. It's available through Auto Paint Supply shops. Not cheap, but guaranteed to work.
Colin
Colin H is offline   Reply With Quote
Old 03-20-2014, 08:20 AM   #10
cdmagda's Avatar
Images: 51
Painting
Zolatone makes a great aluminum primer called Zo-Ferro Basecoat Primer-Sealer. It is good for bare aluminum, as long as it is prepped properly. I used it after stripping the paint on the interior of the '55FC, so it was bare metal, and top coated with Zolatone 20 Series with the activator added...hard as nails. You can't scrape this stuff, won't scuff either.
cdmagda is offline   Reply With Quote
Old 03-20-2014, 08:59 AM   #11
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Search here on the forums for
'Detailed of painting Argosy with a roller'
By boatdoc
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-20-2014, 06:52 PM   #12
1973 Argosy 22
A friend is going to paint it in his shop but it's when he isn't busy. He has jobs backed up till the end of summer now so I might try using a roller.
painting inside frame Kevininwa Repairing/Replacing Floor &/or Frame 13 07-24-2014 10:15 PM
Painting all the sides of a new floor? supergg Repairing/Replacing Floor &/or Frame 11 10-10-2011 12:45 PM
Just finished painting, now have spots all over after drying?? dgreen78 Upholstery, Blinds, Walls & Interior Finishes 16 09-05-2011 07:05 PM
Painting your roof, etc Lumatic Roof 0 05-15-2011 10:29 PM
