Old 12-19-2018, 09:32 AM   #29
1976 Argosy 28
Terrell , North Carolina
I have some questions I hope someone knows the answers to.....
1. can someone tell me the inside distance between the 2 outriggers for the steps?
I ordered a new style step release from ODM and it is different than my steps. http://odmrv.com/catalog/index.php?m...roducts_id=222
the part of the top step that fits into the outrigger is about 22.5" and the new step release is about an inch wider.
2. Has anyone used the curved channel from ODM for the front and back.
http://odmrv.com/catalog/index.php?m...oducts_id=1002
this has the channel for the flooring, but my original did not. Anyway the curve is a little bit off and before I cut it to match the original I wanted to check first.
thanks in advance!
dhbinkley is offline   Reply With Quote
Old 12-20-2018, 02:27 PM   #30
Libertyville , Illinois
Looks great! Do you have any more pictures of the with the tanks installed?
Short563 is offline   Reply With Quote
Old 12-21-2018, 08:45 PM   #31
Caracola's Avatar
1975 Argosy 22
1976 25' Caravanner
Yorkie land , Anywhere
Now I see why you ask me about cleaning...my Argosy did not have that glue and my endcaps are in fiberglass so no rust
Caracola is offline   Reply With Quote
Old 12-23-2018, 02:58 PM   #32
1976 Argosy 28
Finally I'm done (almost) with the POR15 on the frame
Short563...I haven't installed the tanks yet, I'm going to do that after I get the shell back on to make sure I have the layout that I want.
Caracola...Yes my end caps are steel, I had a welder try and cut out some of the rusted areas and reweld in a patch...the first guy I used warped the part where the 3 marker lights are in the front the second guy tried to correct the first mistake and was able to get it pretty close...hoping it works when riveting it back one.
If anyone can send me pictures of the steps, step latch and the distance between the outriggers I'd really appreciate it!
After Christmas time to start the flooring...officially starting the reconstruction...so excited!
Hope everyone has a Merry Christmas!
ID:	330219   Click image for larger version
Old 12-24-2018, 02:25 PM   #33
Your painted frame looks great! Do the steps bolt on or are the welded to the frame?
Old 01-02-2019, 11:30 AM   #34
1976 Argosy 28
Thanks!
The steps are bolted on (2) and then there is a special outrigger that has a slot for the steps to slide in and out.
I'll post a pic when I get a chance.
David
Old 01-02-2019, 06:20 PM   #35
1976 Argosy 28
Both axles POR15'd and reattached with the lift kit.
New tongue jack from etrailer going on tmw.
As I mentioned earlier the new front and rear channels were a little different that the originals that Gussy had, so I had to make some partial cuts to form the channel to the same as the old ones.
I'm using 3/4" Advantech...Hindsight I would have just used the 5/8 so I didn't have to use the router to make the edge that goes in the channel 5/8", also the Tongue and grove seemed like a good idea, but it was harder than I thought to get them fit together...removing the tongue on most the sheet and will use a biscuit jointer to add a little strength.
Not sure if anyone else has had this problem but trying to get everything square is a pain, I finally just started measuring from the front of the 2 main rails to make sure I'm getting to far off. Taking the frame back to the welder Friday to fix some of the outriggers that were not welded on level with the frame rails
Goal is to have the channel and subfloor 100% down by the end of the weekend!
I couldn't find a coupler repair kit so I cleaned up and POR15'd the old one.
Gotta say enjoying putting her back together much more than wire brushing the frame...
Old 04-24-2019, 09:39 PM   #36
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
How is Gussy going?
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 05-08-2019, 07:47 PM   #37
1976 Argosy 28
Thanks for asking...I see you have a new project, the 30 footer looks really nice!
Lots of updates on Gussy.
In late Jan I was able to get the shell back on and brought her home. Bad news is that I didn't think about towing it home (short distance) without the endcaps and front and rear windows in. I took it slow but it bounced some and wrinkled some of panels on the ends....duh!
After I got it home I removed some of the panels that are on the sides of the panoramic windows and will make new ones. there were 2 that were cut wrong and had very little overlap on the window frames...a leak waiting to happen
http://www.airforums.com/forums/atta...0&d=1557364705
http://www.airforums.com/forums/atta...1&d=1557364705
I cleaned all the caulking off the front rib and shell where the end cap will go back in so that I get a good seal and can get to the back of the rivets. Ended up using a propane torch to heat the rib and then scrape the caulk off..best way I could find!
I have the front endcap painted with 2 coats of por-15 and I'm almost ready to it back together.
http://www.airforums.com/forums/atta...3&d=1557364705
ID:	340180   Click image for larger version
Old 05-08-2019, 08:39 PM   #38
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Good to hear you’re still at it!
1975 Argosy 26
1979 Argosy 30
Our 1991 34' Classic Renovation SkatiePower Full-Timing, Winter Living & Workamping 1 11-05-2017 06:44 AM
Hello all, Our 'Valentine' is the love of our life, and fast becoming our 24/7 addict errol108 Member Introductions 2 09-12-2016 10:45 PM
Newbies embarking on a 1976 Overlander Renovation. AXLE HELP! earthmama9 General Repair Forum 26 09-05-2016 08:57 AM
1965 Safari: MayBelle, our renovation doctor2xFour Interior Restoration Forum 1 06-16-2015 10:50 AM
1976 22' Argosy - Restoration (With a touch of Renovation) crabbey1 All Argosy Trailers 7 11-21-2013 08:13 AM
