Old 10-13-2007, 08:34 PM   #1
Dave and Pat's Avatar
1978 Argosy Minuet 6.0 Metre
Madison , Wisconsin
Nuts!
Got a small problem on our '78 Argosy. The problem is, everytime we wind it up, the nut keeps coming off the threaded shaft on the front right stabilizer jack. Any ideas on correcting this? Gettin' tired of lying on my back in the mud to put it back on. We don't have this issue on the other three. Doesn't seem to matter how tight I get it.
Dave
"The man who does not read good books has no advantage over the man who can't read them." -Mark Twain
"If you're not eating meat, the carcasses start piling up." - Bucky Katt
Dave and Pat is offline   Reply With Quote
Old 10-13-2007, 08:44 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It is most likely stripped.
Replace the nut and possibly the bolt and tighten lightly and use locktite.
Michelle TAC MT-0
Sarah, Snowball
Old 10-13-2007, 08:46 PM   #3
Madison , Wisconsin
Thanks cats. It is not stripped, however, but the locktight is a good idea.
Dave
Old 10-13-2007, 09:48 PM   #4
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
tack or spot weld
Kevbo10 is offline   Reply With Quote
Old 10-13-2007, 10:12 PM   #5
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Or if locktite doesn't cut it and welding is awkward you could use epoxy for a more semi-permanent solution.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 10-14-2007, 06:14 AM   #6
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Dave
Hi Dave; Simplest solution to that problem is to use Pinch nut or Nylock Nut. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 10-15-2007, 07:07 PM   #7
Madison , Wisconsin
Boatdoc, I am not familiar with those products. I'll check them out.
thanks, Dave
Old 10-15-2007, 08:22 PM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Drill a hole through the nut and shaft and drive a roll pin through.
Old 10-16-2007, 06:39 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
dave
bring it down next time i have the welder fired up and we can tack all 4 in place.
john
you call them ferrets, i call them weasels.
Old 10-16-2007, 07:27 PM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Mighty convenient offer there Dave! Might be the HD lube is just too good -- your stabilizers still looked pretty good here. Love that Minuet!
Today I just happened to run across another recent thread on this subject. I'll have to keep my eye on them.
5 meter Langford Nahanni
Old 10-16-2007, 07:36 PM   #11
2002 19' Bambi
Lafayette , California
Another alternative to nylon locking nuts ("Nylok") and/or Locktite, is a jamb nut, which is a second nut threaded onto the shaft and tightened down onto the first nut. It works best if you tighten nut one thoroughly and then hold it in place with a wrench while tightening nut two down onto it.
Tim A. is offline   Reply With Quote
Old 10-16-2007, 07:48 PM   #12
Madison , Wisconsin
dave
john
Yah John, sounds good-thanks. You all gotta see John's vintage arcwelder droid someday. It's a life force unto itself.
Dave
Old 10-16-2007, 07:53 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
16 HP opposed twin.
sounds like an antique aircraft.
john
Are we nuts? pbnjsellers On The Road... 19 06-14-2005 10:05 PM
Rusty Nuts Safari Tim Axles 31 03-29-2005 06:37 AM
Lug Nuts jfowler218 Axles 7 11-24-2004 06:57 AM
Am I nuts? Dickwalker Towing, Tow Vehicles & Hitches 3 12-09-2003 10:00 AM
Am I Nuts? (Shakedown II) keylime 1959-69 Tradewind 14 07-05-2003 09:28 AM
