Old 12-31-2011, 02:36 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
No water pump
Have no water pump after checking the trailer after a recent cold snap. I've had the trailer plugged in for two days as the battery had died. I checked the fuses and one was blown, 30 amp, and I replaced it to no avail.
The carpet under the water pump is wet and the pump itself is hot....ok, very warm.
Could a line have split and thus the pump continually run and then burned out?
Thanks for any suggestions.
Dan
Dan S is offline   Reply With Quote
Old 12-31-2011, 04:00 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did it freeze where you are? If so, the water line runs behind the refer ( at least in my Argosy) it may have frozen because of the exposure to the outside air where the refer vents. If the line froze the pump ran until the pressure switch was satisfied and then shut down. If yours is like mine, try getting some heat on the line. A heavy duty hair drier might do it. Open the outside hatch behind the refer a see if the water line passes thru the area, it will be right up against the outside wall.
TG Twinkie is online now   Reply With Quote
Old 01-01-2012, 05:42 AM   #3
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I would think its likely you could have breaks in all sorts of places if the whole system froze. Is it copper or pex? More likely to be the pump if all your pipe is Pex, I think Pex is likely to be more forgiving than copper (although a plumber can correct me on this). Wet under the pump suggests the water in the pump froze and cracked the plastic top to the pump. I have done that several times with my cleaning trucks. If its just a cracked lid, then there are replacement parts that can be bought. This was an easy fix for me when I split the outlet on my pump because of over tightening (lesson there) because we have all kinds of pump suppliers around us. If its a Shureflow then parts and repair kits are available, if its generic, just replace it and make sure the outlets match what you have as they can be male or female.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Water pump Issue. Toronto_Guy Water Heaters, Filters & Pumps 6 09-23-2011 06:45 AM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
