Old 06-24-2007, 05:13 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
No shower
Anyone know why our shower would not spray out at the wand? I had water pressure everywhere else, even where the hose screws into the faucet on the wall. Granted, it sprayed out from that fitting but nothing out the wand....can it be clogged within the hose?
Dan S is offline   Reply With Quote
Old 06-24-2007, 05:38 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Dan
Unscrew the head from the hose and see if that works. Probably junk in the sprayer head.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 06-24-2007, 06:03 PM   #3
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Ditto.
My 05 Safari had that problem a few months ago. There's a filter strain in the connection to the valve itself that I was unaware of. C&R Trailers took it apart and now works better then before!
R/
Safari-Rick )
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 06-24-2007, 06:09 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If this is the first time you used it....Did you push the on/off button on the head to on......
Old 06-24-2007, 07:30 PM   #5
Dan S's Avatar
1975 Argosy 26
OK, sometimes the obvious isn't so. I had no idea the shower head had a on/off button.....yes it works just fine now.
Let me lick my wounds before I post my next question that inevitably will be solved by turning something on or off. That said my floor is wet again after a very wet drive home.
Dan
Old 06-24-2007, 07:55 PM   #6
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
All together now (and we're allowed because we've ALL had that or similar experiences) ... 'Doh!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 06-24-2007, 08:38 PM   #7
USN/LAPD Retired
Oh Boy......
AIR #: 8129
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
Resurfacing the shower, sink surround BobbyW Sinks, Showers & Toilets 11 10-06-2006 10:20 AM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
