Old 08-27-2011, 06:27 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
No power!
Got the argosy back yesterday with a new furnace and BAL jacks. I installed 4 new speakers and it sounded great.
I went to plug in to 120 tour. The ac and it dimmed and finally went out. No 12 volt power either. I checked the 50 amp fuse and it blew. I replaced the 50 amp fuse, checked the breakers and still nothing no 120 or 12 volt anything
I'm charging the battery now as it seems low.
Did I fry the Univolt?
Dan
Dan S is offline   Reply With Quote
Old 08-27-2011, 06:42 PM   #2
Dan S's Avatar
1975 Argosy 26
Could one of the speakers I installed be shorting out against the side of the trailer? Everything worked while I was on 12 volt power. It was when I plugged into the 120 when it dimmed and then went out.....
Old 08-27-2011, 06:47 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Sounds like you have it narrowed down nicely already, Dan.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 08-27-2011, 06:53 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The speakers have nothing to do with 120 power. If one of the speakers was shorting, it would take out the stereo fuse and it would have done it on the 12v power.
Vaughan
Old 08-27-2011, 07:00 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
Am I reading that nothing works now. No 120 volt, no 12 volt . . . nothing?
Old 08-27-2011, 07:00 PM   #6
Dan S's Avatar
1975 Argosy 26
.... So it may be as easy as just checking the speaker wires?
Old 08-27-2011, 07:04 PM   #7
Dan S's Avatar
1975 Argosy 26
Correct, nothing is working. I checked the breakers and they are not tripped.
I plugged the trailer into the truck via the 7 prong plug and the running lights work but not the inside lights or anything else....real frustrating since I just got it home after a new furnace installed and the speakers working and sounding good.
Old 08-27-2011, 07:06 PM   #8
DanielB's Avatar
This should be fairly straightforward to test. If you have one of those electronic meter gizmos. You can check the wiring from points A to B on different sections of the wiring beginning where it comes in the trailer.
The interesting thing is that the speakers were the only thing that changed, which usually points to the primary suspect. It may just be a coincidence with the speakers.
- Andrew Carnegie
Old 08-27-2011, 07:49 PM   #9
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
I would not think both systems could go out at the same time unless the batteries were already dead and the univolt was powering the 12v system thru the dead batteries...and then the 120v breaker from the 120v circuit you plugged into (house, garage) tripped then you turned on the AC. That would cut the power to the 120v system and the 12v systems at the same time.
KeithC is offline   Reply With Quote
Old 08-27-2011, 08:11 PM   #10
1977 Argosy 24
Milltown , Wisconsin
Are you sure the plug that you are plugged into is still hot? Maybe the breaker that powers the land line plug is tripped. I would remove the speakers and look behind them and see if you damaged a 110 volt wire when you installed them. Some where you may have pinched off the insulation on one of your 110 volt wires and shorted it out when you did the install on the stereo.
ventport is offline   Reply With Quote
Old 08-27-2011, 08:22 PM   #11
Dan S's Avatar
1975 Argosy 26
The plug is hot because I'm using it for the battery charger. If it was just the shore power my 12 volt should be working since the battery has to have enough juice by now to simply turn a light on.
Old 08-27-2011, 08:50 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You should look for a 50 amp fuse on the negative side of the DC circuit. They are normally mounted on the skin of the trailer.
As far as the 120 volt AC power goes, I would start by turning off all of the circuit breakers, then turn on the main and one of the remaining breakers. Check to see if things work, if so turn on another breaker and so on. You should be able to isolate the circuit and then determine where the problem is. Get the 120 volt problem resolved first, then go to the 12 volt DC.
Let us know what you observe.
Are you using an extension cord? If so the problem could be in the size, especially if you run the air conditioning.
Old 08-27-2011, 09:25 PM   #13
Dan S's Avatar
1975 Argosy 26
I've been charging the battery and decided to test things. After I plugged in the 110, the lights and ac worked but the stereo just for a minuet. As I was dinking around, if I turned a light on the stereo would dim or turn off.
I then unplugged and tried the 12v but nothing worked. The 50 amp fuse mounted on the floor appears pitted or a little odd but not blown and still intact. I dint have another 50 but will get one in the morning.
I'm going to leave the 110 plugged in over night and see what that does....would that not be charging the battery via the Univolt.
Still very frustrated but thanks to all for the advice.
Dan
Old 08-28-2011, 05:31 AM   #14
DanielB's Avatar
Those screwdriver looking things with the bulb in the handle only cost a few bucks. They make it really easy to test for 12v current.
- Andrew Carnegie
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
Stumped by power steering dadstoy Mechanics Corner - Engines, Transmission & More... 14 05-30-2011 01:57 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
