Old 08-28-2011, 08:36 AM   #15
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Daniel,
Are you suggesting that with one of the testers I touch it to one side of each fuse holder to see if it has power and that will identify which fuse is bad?
Dan
Dan S is offline   Reply With Quote
Old 08-28-2011, 09:05 AM   #16
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Can you hear the Univolt? They are noisy and, if they are working, you can hear them buzzing. Looks like you are going to be crawling around looking at fuses and circuits in the front of the Minuet. Is the Univolt plugged in? If the lights work (the 12 V lights) then the Univolt is working. It sounds like mistakes in the wiring for the stereo where you have a short or wires crossed that should not be crossed. Remove the fuse that goes to the stereo and try the lights. Then kill the lights and try the stereo. Those two items should not affect each other. Start at the fuse block to see what fuse powers which circuit. Fuses are often in a long block near the water pump. There may be a cover on the block. If the jacks are powered, I'd be looking at the wiring done for them.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 08-28-2011, 10:03 AM   #17
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
These things.. ground with the alligator clip and stick the wire with the pointy end of the screwdriver thingy and if there is current the light comes on.
Costs 3-4 dollars. It's awesome.
ID:	138872   Click image for larger version
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 08-28-2011, 10:43 AM   #18
Splitrock's Avatar
Sioux Falls , South Dakota
For the 120 volt testing, I just use a no contact voltage tester. I get them at the home centers for about $10.
Old 08-28-2011, 11:04 AM   #19
1977 21' Globetrotter
Davis , California
Electrical testing and troubleshooting
The problem you have requires some patience and systematic searching for the problem. I would get both the circuit tester described above, and an inexpensive multimeter (about $15 at Radio Shack). The multimeter can be used to measure a variety of voltages, both AC, such as shore power, and DC, such as your battery (DC voltage gives you a reading on the charge state of the battery, plus resistance, good for checking fuses and circuits for good connections.
In your case, I would start at the source for the power, and work 'downstream' to the individual circuits and components on those circuits. don't forget, your furnace changed or was worked on (blower, 12 volt). For example, do I have 120 volt at the plug for the trailer? Then, do I have 120 volts at the trailer receptacles? If not check for tripped or bad circuit breakers... Is the Univolt o.k.? You can check for a bad circuit by, in the extreme, removing all fuses, testing them, and adding them back one at a time.
You can do an Internet search on testing fuses,and circuits, and troubleshooting that should help.
Sorry to be so long winded, it's a little hard to gauge from text messages what your level of expertise is.
flyflinger is offline   Reply With Quote
Old 08-28-2011, 11:50 AM   #20
Dan S's Avatar
1975 Argosy 26
Solved
Ok, I went and bought the 12v tester and a couple new 50 amp main fuses.
I could see I had power into the first 50 amp fuse but nothing after that. The odd thing is that it is the one that was blown and I replaced it with one that was in the trailer and was intact. The downstream 50 amp was pitted and I thought for sure that was the issue. When I replaced the first 50 amp with a nice new gold colored fuse everything lit up.....thanks to all for the advice.
Not sure I want to press my luck by plugging in and seeing if that trips everything up again. I never actually use plug in power as we as always camp at the sites without it and we don't actually need it.
Thanks again all, I appreciate the help.
Dan
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
Stumped by power steering dadstoy Mechanics Corner - Engines, Transmission & More... 14 05-30-2011 01:57 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
