Old 06-13-2016, 06:25 PM   #1
Erie , Colorado
No lights or ceiling fan
I just bought a 1977 20ft Argosy. When I plugged it in right when I got it I had power to everything, lights, fridge, AC, fans. After a few days I lost all inside lights and the two ceiling fans. The AC unit works fine as do all the plug ins and the fridge. The only thing that stopped working were the lights and the two small fans. I have checked all fuses and they are working. I didnt have a battery plugged in with it for the first few days. Since the issue happened I went and bought a battery but that didnt fix anything. What could this be? Do I need a new converter?
Derek
dodonne2 is offline   Reply With Quote
Old 06-13-2016, 06:33 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you're plugged in, and with a new (presumably charged) battery, but none of the 12V stuff works, one of the main battery fuses or the converter may be the culprit.
Old 06-14-2016, 01:50 PM   #3
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
Time to break out your voltmeter and trace the power and check the grounds.
fluxcap is offline   Reply With Quote
Old 06-14-2016, 03:00 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
I see where you checked the fuses on the hot side. I also think that there is large fuse on the 12 volt ground side. If that fuse is blown, you still won't get a complete circuit even if the fuses on the hot side are testing ok.
Trnpk Crsr is offline   Reply With Quote
Ceiling lights flicker, tail lights are dim Zeitlupe 2011 - 2015 International 11 07-01-2016 07:29 AM
Roof locker lights/ceiling fan out in 73 TW kpaulette Lights - Interior & Exterior 8 10-14-2010 05:18 PM
ceiling vent fan question? wayne.yl Roof Vents, Skylights & Fans 6 06-24-2004 03:49 AM
Ceiling Fan? Fun-Lovin General Interior Topics 6 08-20-2003 08:44 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
