01-25-2008, 01:55 PM
1975 Argosy 22 Rear Door
TV is '99 Range Rover 4.6HSE
Newbie owner of 23' rear door - pulling issues?
Hiya,
We just bought a 23' Argosy rear door and had an experience shipper tow it from Ohio to California using a large, diesel pickup. During their trip, the drivers said the Argosy was TOUGH to pull, even with the sway bar installed, etc. In fact, the prior owner seemed to always have issues related to towing and said one of the reasons they were selling was because the trailer was hard to tow, especially at speeds of 50MPH+.
My question - are there known issues of ease-of-towing with this particular model and/or Argosy's in general? Should I look for a bent frame/axle/?? to see what's causing the problem? Could it be because the rear-door model has a weight distribution issue or something?
Like I said, I'm a total newbie, so any help is greatly appreciated.
01-25-2008, 01:58 PM
Aluminut
2004 25' Safari
Axle and brakes come to mind...these are easy tow trailers.....if the diesel had an issue, then something has gotta be wrong and the only place I'd think to look first at would be the axle(s) and brakes.
01-25-2008, 02:02 PM
St. Cloud
What he said. Axles, bearings, brakes. These are light, well balanced units. They should tow very easily with a moderate sized tow vehicle.
Congrats on a unique fun model!
01-25-2008, 02:07 PM
Retired.
, At Large
The rear door 22 and 24 foot models (no 23 offered, Argosy was even number lengths, Airstream odd-numbered lengths) have an unusually low tongue weight, this may be partly to blame for the hard to tow feeling.
IIRC, a regular 24' had a tongue weight of around 550 pounds, and a rear-entry model was around 400. This COULD cause a feeling of squirrelyness.
I towed an Argosy 24 front entry with a Dodge Dakota, and it was very easy to tow.
01-25-2008, 02:11 PM
1979 23' Safari
1954 29' Liner
Orange
Originally Posted by mendosoft
Hiya,
What does "hard to tow" mean? Some specifics would help to solve this problem.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
2002 25' Safari
Dewey
What did he mean by tough to tow. Since he said at 50+ MPH, it most likely is a sway issue. I would look at weight as being a possible issue. The hitch weight should be in the 10% - 15% of the trailer weight for a good tow. If the hitch weight is too low, sway becomes a real issue.
Richard
01-25-2008, 02:34 PM
Right, my bad - it's a 22'
This looks like a great forum, and thanks for the multiple responses re: towing problems. My notes:
1. Yeah, it's the 22 rear door.
2. I think the tower was talking about sway, i.e. when a big rig or something passed them, you really had to have a hold of the tow vehicle's steering wheel. They said 'even with the sway bar', it was hard to tow. My guess is that it started to move around a) at speed > 50mph and b) when side draft from a passing big rig.
3. I'm relying on information over the phone rather than direct experience, so it might be hard to convey the exact dynamics. I WILL ask them for more info when I talk to them in 30 mins.
I'll post more info when I have it. I may be able to ask the seller re: what their experience was as well.
Back w/you soon - thanks!
Steve
01-25-2008, 02:52 PM
Trailer has no propane tanks - could that affect hitch weight?
I do know that the trailer is arriving w/o propane tanks, so maybe that could make the hitch weight to total weight ratio too low? I'm not sure if the prior owner ever had tanks on and/or if that affected the towing experience.
01-25-2008, 03:02 PM
St. Cloud
Yes. If the tongue weight goes much below 10% of trailer gross weight, it gets like trying to throw an arrow backwards through the air -- it'll try to switch ends on you. This can get very dangerous!
Do you have the manual? Argosy published one manual to cover all models in a given year. It gives base weights and option weights. That will give you a guess on curb weight. The manual also include this technique - http://www.airforums.com/forums/f464...ale-24195.html
01-25-2008, 03:07 PM
2019 22' Sport
High River
, Alberta
Has the trailer been modified in a way that has changed its centre of gravity? I particulary thinking of extra weight in the rear, or extra weight up high.
01-25-2008, 03:58 PM
Argosy built this floor plan both in a rear door and a front door model. The front door model had the axels mounted farther back on the frame than the rear door model. If you look in the Archives section of Vintage Airstream Home you'll see what I mean. With the rear door model, the axels are farther forward, the hitch weight is significantly less, and there is more rear overhang which contributes to poor towing. Couple things to consider. 1) Load the trailer heavy up front and always empty the holding tanks before hitting the freeway. 2) Use double sway bars - one on each side of the hitch. 3) It sounds crazy, but run the next size smaller tire on the front axel. Might just add a little more hitch weight. Airstream had the same problem with some of the '80s 34' frames designed for front kitchen floor plans but were used for front lounge models when the front kitchen did not sell well. Their solution was to add solid steel bars inside the a-frame at the front of the hitch to increase hitch weight - not really a great solution. Friends who bought one of those nearly ended up in the ditch before they traded it in for a 34' Classic motorhome. Darol
01-25-2008, 05:03 PM
2003 22' International CCD
Whittier
Welcome to the Forums
Welcome to the forums. Lots of experience here. The towability issues are very important to solve. It's a real safety issue.
To help diagnose the tow issues, be sure to take the trailer to truck scales and take several measurements. Total wt of trailer as you received it. Disconnect from tow vehicle and get the axle wt and tongue wt together. Then the axles by themselves. Then the left side wheels and then the right.
Review of the data will determine if it's a wt and balance problem or if you need to look elsewhere. Post the data here and we'll help interpret if you like. The cost to weigh is very nominal. Explain to the scale operator that you are trying to diagnose a safety issue and they will help you as long as you're not there at a busy time. CAT scales are a major franchise that operates truck scales.
01-25-2008, 05:26 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
What kind of tires are on it also? If it's "P" rated tires, not "ST" (or Special trailer) the soft sidewalls will contribute to sway. Gary and Janet (Janet is a moderator here) have a simular trailer - I don't think they've had any issues with it. My bet is underinflated "P" car tires, no propane tanks, and an empty fresh water tank. Get good trailer tires, inflate them to max recommended pressure, fill the propane, and get some water in the tank it at will be fine.
Also, check how it's hitched up and weigh (search "trailer and scales" or "CAT scales" ) to find out how to measure the weights of the your trailer tires, and the weight distribution of hitch weight on the front / rear axles of your tow vehicle. You want the set up to be level trailer to tow vehicle and front to back on the tow vehicle. My bet is that the trailering folks just hitched up to their p/u and pulled away. Take a pic before they unhook for us to look at (from the side of the trailer / p/u). My bet is the trailer is a bit nose high looking from the side of the setup (as in the hitch ball is too high). That will increase sway.
I don't think you will have any further issues once properly set up.
Of course, if it's "hard to pull" based on just getting up to speed, then it's a brake / axle bearing issue.
Also, I'm not sure where in CA you are, but if you live down south by Newport Beach, send a PM to member Uwe. He might be able to help you with your setup as well. He's a great wealth of knowledge, even if he denies his abilities!
Send pics when you get it, and welcome aboard!
Marc
01-26-2008, 08:56 AM
Thanks! And more info to follow
Thanks for all the info. We'll hit each item and continue to diagnose the situation re: tires, weight dist, axles/brakes/bearings, etc.
The trailer is stuck in Reno, NV right now headed to our home in the San Francisco Bay Area. During the transport, one of the forward curved windows took a rock and shattered, so it's in Reno waiting for a custom replacement window. Hopefully, that'll go smoothly - the OEM replacements are apparently very hard to come by - and the window repair shop says they can make a mold of the window and get a solid fit. We'll see!?
FYI - I started this thread ( http://www.airforums.com/forums/f227...3-a-39264.html) to track that repair and will continue to post updates as we move forward.
So once I have the trailer in hand, can take pictures and can diagnose in person, I'll continue this thread and see where we end up. That'll likely be a week or so after we get over to Reno to pick up the trailer.
01-26-2008, 11:40 AM
Some more thoughts: The hitch ball height of the TV should be close to 19", unloaded. When the hitch is adjusted properly, TV and trailer should both be as close to level as possible. Weigh the trailer. Determine the wheel weight, hitch weight, and total weight. I'm betting the hitch weight is going to be around 300 lbs which is much too light. Your trailer has the battery mounted just behind the wheels on the roadside. Move it up front under the couch. In fact, add a couple more batteries for extended boondocking. Use either AGM or Gellcell batteries to solve the gassing problem. Use #8 THHN stranded copper wire to connect the batteries to the 12V distribution box. Experiment with smaller tire size on the front axel. Check hitch weight again with full propane tanks, full fresh water tank, and empty holding tanks. Hitch weight should be at least 10% of the total trailer weight, preferable a little more. If you're in the ballpark, consider remounting the rear axel about an inch lower than the front axel. This will require a qualified trailer mechanic (think horse trailer, utility trailer types). The advantage is that you can go back to the same size tires on both axels. The axel capacities on your trailer should be 2600 lbs ea, so having the rear axel carry a little more weight isn't going to matter since your trailer probably won't weigh much more than 3800 lb loaded. Gary and Janet's trailer mention above is a 24' model which has the axels mounted farther back than yours and does not have the same towing characteristics. Be prepared to take your time on your trip home from Reno. You have not mentioned what you're using for a TV which will make a lot of difference. Darol
01-26-2008, 07:46 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
Ahhh... thank's Darol. I thought Gary's trailer was the same. I'd love to see pics of this new trailer! Sounds like it's balanced right in the middle!
I wonder how the euro trailers are stable with their lower hitch weight... course they tow slower too, don't they?
Marc
02-02-2008, 04:09 PM
I read in your window repair post that you're towing with a Range Rover. Have you already had it wired for the trailer? If not, I suggest you check into that BEFORE you head off to get the trailer. Rover "electrics" are very English and hard to match up with the standard RV plugs used this side of the pond. Also, it's a very short wheel-based rig which will contribute to poor towing characteristics of the trailer. Please be careful! Darol
02-02-2008, 04:42 PM
Here's my info re: towing w/'99 Range Rover 4.6...
Darol, thanks for the warning.
Here's a link to info on the 4.6 which indicates that once you get it set up it tows fine, especially if you have the stock auto-height adjusting suspension. My RR was bought used and had already been through a spring conversion since most people opt for this when the air suspension fails (eventually, usually near 80-100k miles). So I'm riding on standard springs rather than air suspension, but according to this article that should still be fine, assuming the trailer/hitch setup and weight are appropriate.
Here's that link, and yes I'll be careful regardless!
Towing with a Range Rover
1975 22' Argosy Rear Door
Towed By: 1999 Range Rover 4.6HSE (fulltime 4x4)
02-03-2008, 03:52 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
Hey there... I'd love a pic of your Range Rover and Argy when you get it... sounds like a nice looking combo. Just FYI, your link didn't mention weight transfer hitches... I think you mentioned it, but do use one to move some of the hitch weight to the front wheels of your Rover.
I didn't read about your propane tank decision, but getting 30# tanks vs. the 20# (in either steel or aluminum) would help put your weight forward. You can drill or punch out the little press pin that holds the propane tank rod in place to make the rod longer. Most of us that have gone to this trouble just buy some 1/2" threaded rod from a big box store (Home Depot or the like) and double nut the rod above and below the rod holder to make a more sturdy propane holding system.
Search propane tank rod or simular to find some pics of the solution.
Marc
03-28-2008, 06:22 PM
Followup re: newbie w/22' rear, Range Rover 4.6 tow rig...
After two months in storage we've now received the '75 22' rear Argosy. We've towed it to our excellent restoration person in Nevada City (CA) where she will be renovated over time. Great midsize trailer, IMO.
The tow issues were totally mitigated w/a Reese equalizer hitch. This eliminated most of the sway and our trailer was running light and empty. Prior to the Reese hitch, she'd sway way too quickly...not a fun ride.
Tested the setup on a tough pull from Reno NV to Nevada City CA. That's over I-80 Donner Summit (near Tahoe) that goes to 7200 feet. The Rover worked hard but did the work, and the trailer/tow rig combo towed very well given the VERY demanding road, both in terms of elevation gain but also very (very!) poor road surface in the slow lane. If the roads had been smooth (hello federal government, anyone home? We need I-80 funds!), the pull would have been a breeze.
The great thing about the Rover is it's gearing. Drive it in 3rd for a pull and you'll never hit the breaks on the way down. Amazing engineering on the tranny, and though costly to own (I buy mine used) they are great highway and tow vehicles that go through all conditions. I'd recommend the setup with the only caveat being overall pull power up steep grades...
All for now, will report in as we fix the window and get her cleaned up and gussied for some camping in the Sierra this summer. Good stuff.
