Old 08-12-2019, 05:22 AM   #1
1975 Argosy 26
Florence , Massachusetts
Newbie here, what year Argosy
Hi folks,
Newbie here. Picked up as Argosy26, and trying to find out what year it is. Have no paperwork, as it was abandoned on someone's property. May be a little overwhelmed by the amount of work it needs. 90% original interior, but of course the critters moved in while it was sitting empty. A few dents in the body and a few missing covers.
Any help would be appreciated.
Only number I could find was on tongue
Pat#. 2823931
Drew
ID:	349200   Click image for larger version
ID:	349202   Click image for larger version
drewsargosy is offline   Reply With Quote
Old 08-13-2019, 04:23 PM   #2
Libertyville , Illinois
Others have said it should be a silver plaque riveted below the water fill and above the trailer tongue.
Short563 is offline   Reply With Quote
Old 08-13-2019, 04:34 PM   #3
I would say 1972 or 1973 based on the taillights and rear window size. 1974 example I found had a larger rear window. 1975 had a different taillight configuration. Check out VINTAGEAIRSTREAM.com
Old 08-16-2019, 10:33 AM   #4
1976 Argosy 28
Terrell , North Carolina
I agree with short563, but if the plague isn't there the VIN should be stamped on the top of the tongue. Mine is in the curbside near the propane tank holder.
dhbinkley is offline   Reply With Quote
Old 08-17-2019, 05:18 AM   #5
1975 Argosy 26
OK, that is helpful.
No silver plaque at water fill.
I'll look closer at the tongue today.
Old 08-17-2019, 05:37 PM   #6
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Agree that the vin# will be stamped on the tongue. Mine are stamped on the curbside by the propane holder as well. On my 73 I had no clue that the vin was stamped on the tongue until I was preparing it for paint with a wire brush. Mine did not have a tremendous amount of rust but was completely concealed from the years worth of paint that had been applied to the tounge over its lifetime.
I also agree that the trailer appears to be either a 72 or 73. Is there a gray water tank? If a gray water tank is not present it is probably a pre 74. Easy way to tell is to pour a little water down any of the sink drains and see if it runs out the the bottom sewage fitting. It could still have a gray tank if this happens, so the next step would be to verify that you have only one dump valve which should be located dead center of the trunk closest to the body of the trailer (picture below). Maybe someone with a 74 or newer will pipe in with where the gray water dump valve is located.Click image for larger version
1973Argosy is offline   Reply With Quote
Old 08-18-2019, 06:48 AM   #7
Eric 26 Argo's Avatar
Knoxville , TN
Looks like the vin plate is riveted to the tongue in the top photo. With a fare amount of certainty I will say that it is a 26' double bed.
Eric 26 Argo is offline   Reply With Quote
Old 08-18-2019, 12:13 PM   #8
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
The plate riveted to the tounge should be the electrical "low potential only" tag. There should also be a plate riveted to the curbside for propane connection. On my 1973 the vin is stamped on the top of the "c" channel of the tounge curbside. On my 1972 it is on the side of the "c" channel curbside.
ID:	349792Click image for larger version
ID:	349797Click image for larger version
ID:	349798Click image for larger version
year by year updates/changes kbmwrs 2009-2015 Flying Cloud 1 10-14-2017 09:40 AM
Hope everyone has a very safe and wonderful New Year's Eve. Here is to the last sunse Major Tom On The Road... 2 12-31-2015 10:18 PM
Model changes year to year for new buyer? Franswa 2005 and newer - Bambi all models 5 08-11-2014 06:13 AM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
10 Year Rule, Here's a Place.... Pick On The Road... 4 12-10-2003 03:26 PM
