Old 02-08-2014, 02:01 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
New toilet suggestions for Argosy 26?
I'm looking for the best plug/play replacement toilet. Best = ease of replacement. If there is one that is slightly taller/deeper even better.
Has anyone replaced theirs and if so which did you go with?
Dan
Dan S is offline   Reply With Quote
Old 02-08-2014, 03:02 PM   #2
1986 31' Sovereign
Miami , Florida
Sealand Traveler for us. Taller, actual porcelain, simple and rugged.
Mike
Old 02-09-2014, 08:34 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I installed an Aqua V in our Argosy 26'. I used the low profile unit because it sits on a platform.
Old 02-09-2014, 09:07 AM   #4
Dan S's Avatar
1975 Argosy 26
Did the aqua v require any modifications ? How difficult of a job is it?
Thx
Dan
Old 02-09-2014, 09:47 AM   #5
1974 Argosy 20
Kooskia , Idaho
I put a new Thetford Bravura in mine, but it did require removal of the little plastic compartment over the rear top of the toilet, so the lid can be lifted.
Old 02-09-2014, 11:40 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I installed a new platform (because the old one was rotted) along with a new toilet flange/tank adaptor. Also removed the cover for the "secret" compartment behind the toilet. Never got around to making a new cover.
I also chose the hand flush instead of the foot flush model. Because the pedal on the foot flush would have been 8"+ above the floor.
Four years and 20K miles. It still works great.
Old 02-09-2014, 11:50 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Aqua V Install
Here are a couple of pics. Before and after.
http://i1166.photobucket.com/albums/q613/dougbowman88/PC190166.jpg
http://i1166.photobucket.com/albums/...8/IMG_0293.jpg
http://i1166.photobucket.com/albums/q613/dougbowman88/Twinkie%20Ugrades/IMG_0355.jpg
Old 02-10-2014, 01:20 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Pics Gone
Lets try this again.
http://i1166.photobucket.com/albums/...g/IMG_0293.jpg
http://i1166.photobucket.com/albums/...g/PC190166.jpg
http://i1166.photobucket.com/albums/.../IMG_0355R.jpg
Old 02-10-2014, 02:06 PM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Dan
Sealand Traveler here as well - no need to cut up the storage compartment behind toilet.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 02-14-2014, 07:01 PM   #10
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I put a new aqua magic v into my Argosy motorhome. It sits up on a small stand but it was a perfect plug and play. Make sure you get the low profile version. The handle flush or foot flush is your preference, I got the foot flush. Hope this helped
Sent from my SCH-I605 using Airstream Forums mobile app
mprokop87 is offline   Reply With Quote
Old 02-15-2014, 02:07 PM   #11
Dan S's Avatar
1975 Argosy 26
How do the toilets attach to the base? I don't see any bolts etc. this is a pic of my existing toilet.
Dan
ID:	205650   Click image for larger version
Old 02-15-2014, 03:05 PM   #12
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
There should be two bolts, one on either side and they are covered with a plastic cap. If you don't see any, try twisting the toilet to the left or to the right.
Old 02-15-2014, 07:54 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is the original toilet. As I recall there is one bolt accessible behind the flush pedal, the other is accessed thru the removable plug inside the toilet bowl.
It's been 4 years do I could be wrong.
Old 02-15-2014, 08:38 PM   #14
Dan S's Avatar
1975 Argosy 26
Under the pedal and a hidden one would make sense since I can't see them, I'll check tomorrow.
If the bolts are where you described, I assume a Aqua magic V will not be an easy swap out?
Funny toilet vonprum Classic Motorhomes 3 02-11-2012 08:02 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
